Hey.
Spanishboy9
Hey.
Post by Spanishboy9 »
Hey I'm new to these forums but I just wanted to ask is there any possible way to make F@H run faster?
Re: Hey.
Welcome to the forum Spanishboy9.
Yes there is. ;)
Re: Hey.
Close unwanted programs that can use a lot of resources and don't use processor intensive applications (for CPU Client) or play heavy games (for GPU Clients). If possible you can also upgrade your hardware and overclock it (if you have a good understanding of PCs) or run F@H on dedicated folders.
Edit -
I noticed that the posting is done in S@H (Storage@home) rather than F@H section.
Edit by Mod: Topic moved to General F@H.
Re: Hey.
Your FAH production rate also depends on which client you install and whether it makes use of all the computing power of your hardware. If you describe your hardware and tell us which client you installed we may be able to offer other suggestions.
