Project: 5767 (R10, C13, G2023) -- 13 second frames GTX 275
jevans64
Post by jevans64 »
It is not really a problem but I've never seen frame times like these before on this project.
[17:44:49] Folding@Home GPU Core
[17:44:49] Version 1.31 (Tue Sep 15 10:57:42 PDT 2009)
[17:44:49]
[17:44:49] Compiler : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 14.00.50727.762 for 80x86
[17:44:49] Build host: amoeba
[17:44:49] Board Type: Nvidia
[17:44:49] Core :
[17:44:49] Preparing to commence simulation
[17:44:49] - Looking at optimizations...
[17:44:49] DeleteFrameFiles: successfully deleted file=work/wudata_09.ckp
[17:44:49] - Created dyn
[17:44:49] - Files status OK
[17:44:49] - Expanded 46644 -> 252912 (decompressed 542.2 percent)
[17:44:49] Called DecompressByteArray: compressed_data_size=46644 data_size=252912, decompressed_data_size=252912 diff=0
[17:44:49] - Digital signature verified
[17:44:49]
[17:44:49] Project: 5767 (Run 10, Clone 13, Gen 2023)
[17:44:49]
[17:44:49] Assembly optimizations on if available.
[17:44:49] Entering M.D.
[17:44:55] Tpr hash work/wudata_09.tpr: 101230482 3608077767 1148029928 3945415353 692320287
[17:44:55]
[17:44:55] Calling fah_main args: 14 usage=100
[17:44:55]
[17:44:55] Working on Protein
[17:44:56] Client config found, loading data.
[17:44:56] Starting GUI Server
[17:45:09] Completed 1%
[17:45:23] Completed 2%
[17:45:36] Completed 3%
[17:45:49] Completed 4%
[17:46:03] Completed 5%
[17:46:16] Completed 6%
[17:46:30] Completed 7%
[17:46:43] Completed 8%
[17:46:57] Completed 9%
[17:47:10] Completed 10%
[17:47:24] Completed 11%
[17:47:37] Completed 12%
[17:47:50] Completed 13%
[17:48:04] Completed 14%
[17:48:18] Completed 15%
[17:48:31] Completed 16%
[17:48:44] Completed 17%
[17:48:58] Completed 18%
[17:49:11] Completed 19%
[17:49:25] Completed 20%
[17:49:38] Completed 21%
[17:49:52] Completed 22%
[17:50:05] Completed 23%
[17:50:19] Completed 24%
[17:50:32] Completed 25%
[17:50:45] Completed 26%
[17:50:59] Completed 27%
[17:51:12] Completed 28%
[17:51:26] Completed 29%
[17:51:40] Completed 30%
[17:51:53] Completed 31%
[17:52:06] Completed 32%
[17:52:20] Completed 33%
[17:52:33] Completed 34%
[17:52:47] Completed 35%
[17:53:00] Completed 36%
Nathan_P
Not currently folding
Re: Project: 5767 (R10, C13, G2023) -- 13 second frames GTX 275
Post by Nathan_P »
DAMN thats fast!!! Is the card overclocked??? I'm only asking as i have a 275 on the way.
On a serious note though as long as the WU transmits to stanford when its done everything should be OK
_r2w_ben
Post by _r2w_ben »
The work unit's Generation is 2023 so this run is pretty far along. Maybe something occurred within the scientific simulation that makes the frame calculations very easy.
