Project: 3619 (Run 3, Clone 16, Gen 9)
ywlke
Post by ywlke »
I have not been able to transmit this work unit for awhile. If it is relevant, I am using Solaris 10 x64 (8/07) and wine-20050725 with the Windows console client 5.04.
[10:13:16] *------------------------------*
[10:13:16] Folding@Home Gromacs Simulated Tempering Core
[10:13:16] Version 1.10 (Oct 4, 2007)
[10:13:16]
[10:13:16] Preparing to commence simulation
[10:13:16] - Ensuring status. Please wait.
[10:13:22] - Couldn't send HTTP request to server
[10:13:22]   (Got status 502)
[10:13:22] + Could not connect to Work Server (results)
[10:13:22]     (171.64.122.70:8080)
[10:13:22] - Error: Could not transmit unit 01 (completed February 11) to work server.
[10:13:22] + Attempting to send results
[10:13:27] - Server does not have record of this unit. Will try again later.
[10:13:27]   Could not transmit unit 01 to Collection server; keeping in queue.
ChelseaOilman
Re: Project: 3619 (Run 3, Clone 16, Gen 9)
Post by ChelseaOilman »
Any chance this is you?
Hi ke (team 0),
Your WU (P3619 R3 C16 G9) was added to the stats database on 2008-02-14 06:28:44 for 343 points of credit.
ywlke
Post by ywlke »
Nope. FAH username is "wyang".
ChelseaOilman
I'm not sure exactly what's going on, but looking at the server status page, server 171.64.122.70 isn't listed. Looking at the psummary page I can see p3619 WUs are currently being issued by server 171.64.122.82.
How long ago was that WU issued and finished?
Could you run qd on that queue.dat file and post the info here?
I notice you seem to have 3 different client installs on your computer. The third install, probably running machine id 3, you need to reconfigure your client to not use IE Settings. Using IE Settings is resulting in the same WUs being resubmitted over and over again. If it's not that let us know.
Hi wyang (team 42369),
Your WU (P2585 R68 C87 G5) was added to the stats database on 2008-02-11 16:15:34 for 217 points of credit.
Your WU (P2585 R68 C87 G5) was added to the stats database on 2008-02-11 16:15:34 for 0 points of credit.
Your WU (P2585 R68 C87 G5) was added to the stats database on 2008-02-11 18:15:44 for 0 points of credit.
This repeats 18 more times.
ywlke
Post by ywlke »
qd output:
qd released 17 February 2008 (fr 063)
Queue version 5.01
Current index: 2
 Index 3: empty
 Index 4: empty
 Index 5: empty
 Index 6: empty
 Index 7: empty
 Index 8: empty
 Index 9: empty
 Index 0: empty
 Index 1: ready for upload 217.00 pts (8.955 pt/hr) 60.4 X min speed
  server: 171.64.122.70:8080; project: 2585, "p2585_BBA5"
  Folding: run 68, clone 87, generation 5; benchmark 8596; misc: 500, 400
  issue: Sun Feb 10 18:26:51 2008; begin: Sun Feb 10 13:26:55 2008
  end: Mon Feb 11 13:40:49 2008; due: Fri Apr 11 14:26:55 2008 (61 days)
  preferred: Sat Mar 22 14:26:55 2008 (41 days)
  core URL: http://www.stanford.edu/~pande/Win32/x86/Core_79.fah (V1.91)
  CPU: 1,2000 AMD x86; OS: 1,7 Win2K
  assignment info (le): Sun Feb 10 18:26:52 2008; A41B7905
  CS: 171.65.103.100; upload failures: 19; P limit: 5241856
  user: wyang; team: 42369; ID: D4394F3E2B14F60A; mach ID: 3
  work/wudata_01.dat file size: 645422; WU type: Folding@Home
 Index 2: folding now 343.00 pts (0.118 pt/hr) 0.791 X min speed; 5% complete
  server: 171.64.122.82:8080; project: 3619, "p3619_Seq26_Amber03_Native"
  Folding: run 3, clone 16, generation 9; benchmark 8604; misc: 500, 102
  issue: Mon Feb 11 19:27:19 2008; begin: Mon Feb 11 14:27:21 2008
  expect: Thu Jun 12 00:50:00 2008; due: Sat May 17 15:27:21 2008 (96 days)
  preferred: Tue Apr 15 15:27:21 2008 (64 days)
  core URL: http://www.stanford.edu/~pande/Win32/x86/Core_81.fah (V1.10)
  tag: P3619R3C16F9
  assignment info (le): Mon Feb 11 19:27:18 2008; A41A99CB
  CS: 171.64.122.76; P limit: 5241856
  work/wudata_02.dat file size: 364941; WU type: Folding@Home
Average download rate 505.181 KB/s (u=2); upload rate 238.194 KB/s (u=4)
Performance fraction 0.983448 (u=1)
Average pph: 1.378, ppd: 33.08, ppw: 231.5, ppy: 12081
The message in my first post indicates WU being completed 2/11; my guess would then be that it was issued no earlier than 2/9. Based on the above debug output, it looks like it should actually be project 2585.
I'm not sure how to disable "use IE settings", but based on the above output it looks like the one its trying to retransmit is the same one you are seeing as being added for 0 points.
ywlke wrote:I'm not sure how to disable "use IE settings", but based on the above output it looks like the one its trying to retransmit is the same one you are seeing as being added for 0 points.
Start your client with the -configonly flag ;)
ChelseaOilman
project: 2585 run 68, clone 87, generation 5
Index 2: folding now 5% complete
project: 3619 run 3, clone 16, generation 9
Correct.
http://fahwiki.net/index.php/How_do_I_r ... options%3F
Correct.
ywlke
Post by ywlke »
So...any idea how I might be able to get that WU uploaded?
ChelseaOilman
ywlke wrote:So...any idea how I might be able to get that WU uploaded?
It has been uploaded. 20 times already. It will continue to be repeatedly uploaded along with any other WUs you complete until you change the "Use IE Settings" configuration option to "No". After uploading the client isn't deleting the wuresults_0x.dat file because of the configuration setting.
ywlke
Post by ywlke »
As it turns out my setting for use IE was already off. Contents of my client.cfg for that instance (without information about the proxy I use):
[settings]
username=wyang
team=42369
asknet=no
machineid=3
[http]
active=yes
host=*clip*
port=8888
usereg=no
usepasswd=no
[clienttype]
memory=512
ChelseaOilman
ywlke wrote:As it turns out my setting for use IE was already off. Contents of my client.cfg for that instance (without information about the proxy I use
Somehow your settings, or something else, is preventing the client from receiving acknowledgement that the WU was uploaded. As a result the client isn't deleting the wuresults_0x.dat file in the work folder after the upload. You can delete the file manually to prevent further uploads.
