Problem with FAH Screensaver
leny
Post by leny »
Hello everyone, first time poster here. :)
To the point: When the screensaver comes on the first time after configuring it, it's fine. However, from the second time on when the screensaver is activated, all I get is the two circles in the bottom left hand corner, and the protein model. Why is this? What is/has gone wrong?
Thanks,
leny
leny
Re: Problem with FAH Screensaver
Post by leny »
I'm having another problem as well: When I move my mouse and make the screensaver disappear, while the majority of the screen goes back to normal, the bottom of the page (where the start button is) still has remains of the screensaver showing.
This is a newer computer, and I don't know why this would be happening. I had no problems on my old one, which would have been in use for about 6-7 years.
What OS do you use :?:
leny
Post by leny »
I use Windows XP, and I did on the other computer as well. :)
v00d00
Hardware configuration: FX8320e (6 cores enabled) @ stock,
- 16GB DDR3,
- Zotac GTX 1050Ti @ Stock.
- Gigabyte GTX 970 @ Stock
Debian 9.
Ran Seti@Home prior to that.
Post by v00d00 »
The artifacts left from the screensaver when it has closed sounds like a graphics driver problem. Try updating your graphics driver.
