Project: 5914 (Run 0, Clone 591, Gen 6)
thecomputerdude
Post by thecomputerdude »
Don't know if this is really a problem, but the WU keeps coming back after I purge and it does not run well on any of my GPU's (All 9800GTX's). I know it's a very large WU, but shouldn't it at least run somewhat smoothly? This one only runs in spurts of <300it/S and hasn't progressed very much at all- every other WU I've done has run >3000it/S consistently. Is it just the nature of the beast or is this one not properly optimized?
--- Opening Log file [November 22 07:20:49 UTC]
                          http://folding.stanford.edu
Launch directory: C:\Program Files (x86)\Folding@home\Folding@home-gpu
Arguments: -forceasm -advmethods -forceasm -advmethods
Warning:
 By using the -forceasm flag, you are overriding
 safeguards in the program. If you did not intend to
 do this, please restart the program without -forceasm.
 If work units are not completing fully (and particularly
 if your machine is overclocked), then please discontinue
 use of the flag.
[07:20:49] - Ask before connecting: No
[07:20:49] - User name: thecomputerdude (Team 32322)
[07:20:49] - User ID: 34D8FAF21B87D375
[07:20:49] - Machine ID: 1
[07:20:49]
[07:20:49] Loaded queue successfully.
[07:20:49] Initialization complete
[07:20:49]
[07:20:49] + Processing work unit
[07:20:49] Core required: FahCore_14.exe
[07:20:49] Core not found.
[07:20:49] - Core is not present or corrupted.
[07:20:49] - Attempting to download new core...
[07:20:49] + Downloading new core: FahCore_14.exe
[07:20:50] + 10240 bytes downloaded
[07:20:50] + 20480 bytes downloaded
[07:20:50] + 30720 bytes downloaded
[07:20:50] + 40960 bytes downloaded
[07:20:50] + 51200 bytes downloaded
[07:20:50] + 61440 bytes downloaded
[07:20:50] + 71680 bytes downloaded
[07:20:50] + 81920 bytes downloaded
[07:20:50] + 92160 bytes downloaded
[07:20:50] + 102400 bytes downloaded
[07:20:50] + 112640 bytes downloaded
[07:20:50] + 122880 bytes downloaded
[07:20:50] + 133120 bytes downloaded
[07:20:50] + 143360 bytes downloaded
[07:20:50] + 153600 bytes downloaded
[07:20:50] + 163840 bytes downloaded
[07:20:50] + 174080 bytes downloaded
[07:20:50] + 184320 bytes downloaded
[07:20:50] + 194560 bytes downloaded
[07:20:50] + 204800 bytes downloaded
[07:20:50] + 215040 bytes downloaded
[07:20:50] + 225280 bytes downloaded
[07:20:50] + 235520 bytes downloaded
[07:20:50] + 245760 bytes downloaded
[07:20:50] + 256000 bytes downloaded
[07:20:50] + 266240 bytes downloaded
[07:20:50] + 276480 bytes downloaded
[07:20:50] + 286720 bytes downloaded
[07:20:50] + 296960 bytes downloaded
[07:20:50] + 307200 bytes downloaded
[07:20:50] + 317440 bytes downloaded
[07:20:50] + 327680 bytes downloaded
[07:20:50] + 337920 bytes downloaded
[07:20:50] + 348160 bytes downloaded
[07:20:50] + 358400 bytes downloaded
[07:20:50] + 368640 bytes downloaded
[07:20:50] + 378880 bytes downloaded
[07:20:50] + 389120 bytes downloaded
[07:20:50] + 399360 bytes downloaded
[07:20:50] + 409600 bytes downloaded
[07:20:50] + 419840 bytes downloaded
[07:20:50] + 430080 bytes downloaded
[07:20:50] + 440320 bytes downloaded
[07:20:50] + 450560 bytes downloaded
[07:20:50] + 460800 bytes downloaded
[07:20:50] + 471040 bytes downloaded
[07:20:50] + 481280 bytes downloaded
[07:20:50] + 491520 bytes downloaded
[07:20:50] + 501760 bytes downloaded
[07:20:50] + 512000 bytes downloaded
[07:20:50] + 522240 bytes downloaded
[07:20:50] + 532480 bytes downloaded
[07:20:50] + 542720 bytes downloaded
[07:20:50] + 552960 bytes downloaded
[07:20:50] + 563200 bytes downloaded
[07:20:50] + 565848 bytes downloaded
[07:20:50] Verifying core Core_14.fah...
[07:20:50] Signature is VALID
[07:20:50]
[07:20:50] Trying to unzip core FahCore_14.exe
[07:20:50] Decompressed FahCore_14.exe (1298432 bytes) successfully
[07:20:55] + Core successfully engaged
[07:21:01]
[07:21:01] + Processing work unit
[07:21:01] Core required: FahCore_14.exe
[07:21:01] Core found.
[07:21:01] Working on queue slot 02 [November 22 07:21:01 UTC]
[07:21:01] + Working ...
[07:21:01]
[07:21:01] *------------------------------*
[07:21:01] Folding@Home GPU Core - Beta
[07:21:01] Version 1.26 (Wed Oct 14 13:09:26 PDT 2009)
[07:21:01]
[07:21:01] Compiler  : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 14.00.50727.762 for 80x86
[07:21:01] Build host: vspm46
[07:21:01] Board Type: Nvidia
[07:21:01] Core      :
[07:21:01] Preparing to commence simulation
[07:21:01] - Assembly optimizations manually forced on.
[07:21:01] - Not checking prior termination.
[07:21:01] Error: Missing work file=<>
[07:21:01]
[07:21:01] Folding@home Core Shutdown: MISSING_WORK_FILES
[07:21:05] CoreStatus = 74 (116)
[07:21:05] The core could not find the work files specified. Removing from queue
[07:21:05] Deleting current work unit & continuing...
[07:21:09] - Preparing to get new work unit...
[07:21:09] + Attempting to get work packet
[07:21:09] - Connecting to assignment server
[07:21:09] - Successful: assigned to (171.64.65.20).
[07:21:09] + News From Folding@Home: Welcome to Folding@Home
[07:21:09] Loaded queue successfully.
[07:21:10] + Closed connections
[07:21:15]
[07:21:15] + Processing work unit
[07:21:15] Core required: FahCore_14.exe
[07:21:15] Core found.
[07:21:15] Working on queue slot 03 [November 22 07:21:15 UTC]
[07:21:15] + Working ...
[07:21:15]
[07:21:15] *------------------------------*
[07:21:15] Folding@Home GPU Core - Beta
[07:21:15] Version 1.26 (Wed Oct 14 13:09:26 PDT 2009)
[07:21:15]
[07:21:15] Compiler  : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 14.00.50727.762 for 80x86
[07:21:15] Build host: vspm46
[07:21:15] Board Type: Nvidia
[07:21:15] Core      :
[07:21:15] Preparing to commence simulation
[07:21:15] - Assembly optimizations manually forced on.
[07:21:15] - Not checking prior termination.
[07:21:15] - Expanded 68484 -> 357580 (decompressed 522.1 percent)
[07:21:15] Called DecompressByteArray: compressed_data_size=68484 data_size=357580, decompressed_data_size=357580 diff=0
[07:21:15] - Digital signature verified
[07:21:15]
[07:21:15] Project: 5914 (Run 0, Clone 591, Gen 6)
[07:21:15]
[07:21:15] Assembly optimizations on if available.
[07:21:15] Entering M.D.
[07:21:21] Tpr hash work/wudata_03.tpr:  2331899269 1513952068 3325724204 2592265524 1909510409
[07:21:22] Working on Protein
[07:21:22] Client config found, loading data.
[07:21:22] Starting GUI Server
[07:23:10] Opening http://foldingforum.org/...
[07:26:07] Completed 1%
[07:30:53] Completed 2%
[07:35:40] Completed 3%
[07:36:55] Opening C:\Program Files (x86)\Folding@home\Folding@home-gpu\MyFolding.html...
[07:39:57] + Paused
[07:44:16] + Working ...
[07:44:16] Suspending work thread...
[07:44:16] Resuming work thread...
[07:44:51] Completed 4%
[07:47:16] Timer requesting checkpoint
[07:49:57] Completed 5%
[07:50:16] Timer requesting checkpoint
[07:53:16] Timer requesting checkpoint
[07:54:51] Completed 6%
[07:56:16] Timer requesting checkpoint
[07:59:16] Timer requesting checkpoint
[07:59:55] Completed 7%
[08:02:16] Timer requesting checkpoint
[08:04:59] Completed 8%
[08:05:16] Timer requesting checkpoint
[08:08:16] Timer requesting checkpoint
[08:10:00] Completed 9%
[08:11:16] Timer requesting checkpoint
[08:14:16] Timer requesting checkpoint
[08:14:59] Completed 10%
[08:17:16] Timer requesting checkpoint
[08:19:58] Completed 11%
[08:20:16] Timer requesting checkpoint
[08:23:16] Timer requesting checkpoint
[08:24:49] Completed 12%
[08:26:16] Timer requesting checkpoint
[08:29:16] Timer requesting checkpoint
[08:29:46] Completed 13%
[08:32:16] Timer requesting checkpoint
[08:34:41] Completed 14%
[08:35:16] Timer requesting checkpoint
[08:38:16] Timer requesting checkpoint
[08:39:43] Completed 15%
[08:41:16] Timer requesting checkpoint
[08:44:16] Timer requesting checkpoint
[08:44:41] Completed 16%
[08:47:16] Timer requesting checkpoint
[08:49:34] Completed 17%
[08:50:16] Timer requesting checkpoint
[08:53:16] Timer requesting checkpoint
[08:54:28] Completed 18%
[08:56:16] Timer requesting checkpoint
[08:59:16] Timer requesting checkpoint
[08:59:22] Completed 19%
[09:02:16] Timer requesting checkpoint
[09:04:16] Completed 20%
[09:05:16] Timer requesting checkpoint
[09:08:16] Timer requesting checkpoint
[09:09:07] Completed 21%
[09:11:16] Timer requesting checkpoint
[09:13:55] Completed 22%
[09:14:16] Timer requesting checkpoint
[09:17:16] Timer requesting checkpoint
[09:18:42] Completed 23%
[09:20:16] Timer requesting checkpoint
[09:23:16] Timer requesting checkpoint
[09:23:30] Completed 24%
[09:26:16] Timer requesting checkpoint
[09:28:22] Completed 25%
[09:29:16] Timer requesting checkpoint
[09:32:16] Timer requesting checkpoint
[09:33:10] Completed 26%
[09:35:16] Timer requesting checkpoint
bollix47
Re: Project: 5914 (Run 0, Clone 591, Gen 6)
Post by bollix47 »
Your frame times for that WU are reasonable and in line with what my GPUs get. Don't forget that WU gets 1888 points so the PPD should be fairly close to other WUs.
As far as "spurts" that is normal for core 14.
viewtopic.php?f=52&t=10701&p=104991#p104991
You appear to have these arguments specified twice. Perhaps they're listed on both the command line and the extra parameters field? Shouldn't 'hurt' anything but not necessary.
You appear to have a very low checkpoint. The default of 15 should work fine and you won't see so many "Timer requesting checkpoint" messages.
All that being said, your GPU appears to be running as expected and there's no need to purge these WUs. :ewink:
thecomputerdude
Thanks much. I wasn't aware that the spurting was normal, that's why I thought it was buggy. :D
Spurting is normal for FahCore_14. Most of the WUs that you get are for FahCore_11 and it's not normal for them. (The link that bollix gave explains that it's expected.)
