129.74.85.48 - unable to send results
goodyca
Post by goodyca »
I received a WU for project 1031 on Oct 12 19:11:52 2009 UTC from the subject server. The unit was completed on Oct 13 01:12:58 2009 UTC. It has now had 8 upload failures to the subject server and CS 129.74.155.246.
I have attached the relevant parts of the folding log file. I don't see the subject server listed on the "Server Status" page. What do I need to do to get the results from this unit uploaded?
--- Opening Log file [October 10 14:45:32]
# Linux Console Edition #######################################################
                       Folding@Home Client Version 6.02
                          http://folding.stanford.edu
Launch directory: /home/craig/folding/1
Executable: ./fah6
Arguments: -advmethods -verbosity 9
[14:45:32] - Ask before connecting: No
[14:45:32] - User name: goodyca (Team 439)
[14:45:32] - User ID: 6E92394C67EF45F6
[14:45:32] - Machine ID: 1
[14:45:32]
[00:11:50] + Attempting to get work packet
[00:11:50] - Connecting to assignment server
[00:11:50] Connecting to http://assign.stanford.edu:8080/
[00:11:51] Posted data.
[00:11:51] Initial: 4A81; - Successful: assigned to (129.74.85.48).
[00:11:51] + News From Folding@Home: Welcome to Folding@Home
[00:11:51] Loaded queue successfully.
[00:11:51] Connecting to http://129.74.85.48:8080/
[00:11:51] Initial: 0000; - Receiving payload (expected size: 38651)
[00:11:52] - Downloaded at ~37 kB/s
[00:11:52] - Averaged speed for that direction ~176 kB/s
[00:11:52] + Received work.
[00:11:52] Trying to send all finished work units
[00:11:52] + No unsent completed units remaining.
[00:11:52] + Closed connections
[00:11:52]
[00:11:52] + Processing work unit
[00:11:52] Core required: FahCore_b4.exe
[00:11:52] Core not found.
[00:11:52] - Core is not present or corrupted.
[00:11:52] - Attempting to download new core...
[00:11:52] + Downloading new core: FahCore_b4.exe
[00:11:52] Downloading core (/~pande/Linux/x86/Core_b4.fah from www.stanford.edu)
[00:11:52] Initial: AFDE; + 10240 bytes downloaded
[00:11:52] Initial: 8610; + 20480 bytes downloaded
[00:12:01] Initial: B778; + 2590720 bytes downloaded
[00:12:01] Initial: A7BF; + 2600560 bytes downloaded
[00:12:01] Verifying core Core_b4.fah...
[00:12:01] Signature is VALID
[00:12:01]
[00:12:01] Trying to unzip core FahCore_b4.exe
[00:12:02] Decompressed FahCore_b4.exe (7260868 bytes) successfully
[00:12:02] + Core successfully engaged
[00:12:07]
[00:12:07] + Processing work unit
[00:12:07] Core required: FahCore_b4.exe
[00:12:07] Core found.
[00:12:07] Working on Unit 06 [October 13 00:12:07]
[00:12:07] + Working ...
[00:12:07] - Calling './FahCore_b4.exe -dir work/ -suffix 06 -checkpoint 15 -verbose -lifeline 8776 -version 602'
[00:12:07] ******* Log Started 12/Oct/2009 19:12:07 *******
[00:12:07] Core command line: ./FahCore_b4.exe -dir work/ -suffix 06 -checkpoint 15 -verbose -lifeline 8776 -version 602
[00:12:07]                type 1000
[00:12:07]           core_type 180
[00:12:07]            core_ver 0
[00:12:07]    compression_type 1
[00:12:07]           checkbits 104dfe59-7fa5b91c-47aebac7-d39f9056-77c23567
[00:12:07]                 run 117
[00:12:07]               clone 0
[00:12:07]                 gen 0
[00:12:07]             user_id 0x00000000000000000000000000000000
[00:12:07]             work_id 0x00000000000132994aa6eb1200000077
[00:12:07]             mach_id 1
[00:12:07]           data_size 329216
[00:12:07]     compressed_size 38139
[00:12:07]       data_checksum e1a83c53-c6e1b7d7-f9512c63-ff131974-b022fb45
[00:12:07]          project_id 1031
[00:12:07] Reading tar file protomol.conf
[00:12:07] Reading tar file par_all27_prot_lipid.inp
[00:12:07] Reading tar file scpismQuartic.inp
[00:12:07] Reading tar file ww_exteq_nowater1.pdb
[00:12:07] Reading tar file ww_exteq_nowater1.psf
[00:12:07] Digital signatures verified
[00:12:07] =+=+=+=+=+=+=+=+=+=+=+=+=+=+=+=+=+= ProtoMol +=+=+=+=+=+=+=+=+=+=+=+=+=+=+=+=+=+   Description: A rapid PROTOtyping MOLecular dynamics object-oriented
[00:12:07]                 component based framework.
[00:12:07]        Version: 3.1
[00:12:07]   SVN revision: 1698
[00:12:07]     Repository: https://protomol.svn.sourceforge.net/svnroot/protomol/trunk/protomol
[00:12:07]       Homepage: http://protomol.sourceforge.net/
[00:12:07] Report bugs to: protomol@cse.nd.edu, jcoffland@cauldrondevelopment.com
[00:12:07]       Compiler: g++ 4.1.2
[00:12:07]          Flags:
[00:12:07]     Extra libs:
[00:12:07]       Built by: buildbot
[00:12:07] Build platform: posix
[00:12:07]     Build date: Oct  7 2009, 09:10:13
[00:12:07]   Checksumming: Enabled for Folding@Home file protection.
[00:12:07]    Please cite: T. Matthey, T. Cickovski, S. S. Hampton, A. Ko, Q. Ma, M.
[00:12:07]                 Nyerges, T. Raeder, T. Slabach, and J. A. Izaguirre. ProtoMol:
[00:12:07]                 An object-oriented framework for prototyping novel algorithms
[00:12:07]                 for molecular dynamics. ACM Trans. Math. Softw., 30(3):237 265,
[00:12:07]                 2004.
[00:12:07] =+=+=+=+=+=+=+=+=+=+=+=+=+=+=+=+=+=+=+=+=+=+=+=+=+=+=+=+=+=+=+=+=+=+=+=+=+=+=+=+
[00:12:07] Recoverable Error:  Ignoring: Gui false
[00:12:07] Using PDB posfile 'ww_exteq_nowater1.pdb' (544).
[00:12:07] Using temperature 300K for the velocities  (544).
[00:12:07] Using PSF file 'ww_exteq_nowater1.psf' (544).
[00:12:08] Using PAR file 'par_all27_prot_lipid.inp', new charmm force field.
[00:12:08] Using SCPISM file 'scpismQuartic.inp'.
[00:12:08] SCPISM: doSCPISM set to 4.
[00:12:08] Hint:  Reduced fast delta max of ExclusionTable from 31 to 26.
[00:12:08] Random temperature : 302.1K
[00:12:08] Removed linear momentum : (2.339,-1.26819,-1.83357)
[00:12:08] Removed angular momentum : (26.3362,6.41389,-25.291)
[00:12:08] Actual start temperature : 304.461K
[00:12:08] Virial tensor : false
[00:12:08] Molecular virial tensor : false
[00:12:08] =+=+=+=+=+=+=+=+=+=+=+=+=+=+=+=+=+= Outputs =+=+=+=+=+=+=+=+=+=+=+=+=+=+=+=+=+=+Output Checkpoint checkpt 50000 0 ww_exteq_nowater1. ww_exteq_nowater1..
[00:12:08] Output DCDFile ww.dcd 500 false.
[00:12:08] Output FAHFile ../current.xyz 50000.
[00:12:08] Output FAHGUI ProtoMol Project 1 52753 1 Protomol_3.0 0 false.
[00:12:08] Output Screen true 50000.
[00:12:08] =+=+=+=+=+=+=+=+=+=+=+=+=+=+=+=+=+ Integrator =+=+=+=+=+=+=+=+=+=+=+=+=+=+=+=+=+integrator {
[00:12:08]   Level 0 LangevinLeapfrog {
[00:12:08]       timestep 1
[00:12:08]       temperature 300
[00:12:08]       gamma 91
[00:12:08]       seed 2306
[00:12:08]     Force Improper
[00:12:08]     Force Dihedral
[00:12:08]     Force Bond
[00:12:08]     Force Angle
[00:12:08]     Force LennardJones CoulombSCPISM BornRadii -switchingFunction C2 -switchingFunction C2 -switchingFunction Cutoff -algorithm NonbondedCutoff
[00:12:08]       -switchon 15	 # C2 swf switch on
[00:12:08]       -cutoff 20	 # C2 swf cutoff
[00:12:08]       -D 80	 # Bulk solvent dielectric
[00:12:08]       -switchon 8	 # C2 swf switch on
[00:12:08]       -bornswitch 3	 # Born Switch type
[00:12:08]       -cutoff 5	 # cutoff swf cutoff
[00:12:08]       -cutoff 20	 # algorithm cutoff
[00:12:08]     Force BornSelf -switchingFunction Cutoff -algorithm NonbondedCutoff
[00:12:08]       -D 80	 # Bulk solvent dielectric constant.
[00:12:08]       -cutoff 5	 # algorithm cutoff
[00:12:08]   }
[00:12:08] }
[00:12:08] =+=+=+=+=+=+=+=+=+=+=+=+=+=+=+=+=+= Topology +=+=+=+=+=+=+=+=+=+=+=+=+=+=+=+=+=+Atoms                : 544
[00:12:08] AtomTypes            : 32
[00:12:08] Bonds                : 553
[00:12:08] Angles               : 989
[00:12:08] Dihedrals            : 1460 (1529)
[00:12:08] Impropers            : 90
[00:12:08] Molecules            : 1
[00:12:08] Water                : 0
[00:12:08] Pairs                : 724
[00:12:08] Degree of freedom    : 1629
[00:12:08] Molecule pair dist's : true
[00:12:08] Exclusion pairs      : 2962
[00:12:08] Max exclusion dist   : 26
[00:12:08] Time                 : 0
[00:12:08] CellManager          : Cubic
[00:12:08] BoundaryConditions   : Vacuum orthogonal
[00:12:08] coulombScalingFactor : 1
[00:12:08] exclude              : scaled1-4
[00:12:08] cellSize             : 5
[00:12:08] Atom density         : 0.00352248026312843
[00:12:08] Atom/cell            : 0.440310032891054
[00:12:08] Real cell size       : (5,5,5)
[00:12:08] Cell dimension       : (12,11,11)
[00:12:08] Simulation box       : (-inf,-inf,-inf)-(inf,inf,inf) (inf,inf,inf)
[00:12:08] Particle             : (-63.18,16.969,23.937)-(-5.439,68.229,76.115) (57.741,51.26,52.178)
[00:12:08] Particle extended    : (-63.18,16.969,23.937)-(-5.439,68.229,76.115) (57.741,51.26,52.178)
[00:12:08] =+=+=+=+=+=+=+=+=+=+=+=+=+=+=+=+=+=+=+=+=+=+=+=+=+=+=+=+=+=+=+=+=+=+=+=+=+=+=+=+
[00:12:08] Step :       0, Time :      0.000 [ns], TE :   -3088.4238 [kcal/mol], T :   304.4608 [K], V :    154436.64 [AA^3]
[00:12:08] GUI Server started
[00:27:08] Checkpointing: Step 43214. . .done
[00:29:29] Step: 50000
[00:29:29] Checkpointing: Step 50000. . .done
[00:29:29] Step :   50000, Time :      0.050 [ns], TE :   -2973.7885 [kcal/mol], T :   291.6785 [K], V :    154883.12 [AA^3]
[00:42:09] Checkpointing: Step 86075. . .done
[05:53:58] Step: 950000
[05:53:58] Checkpointing: Step 950000. . .done
[05:53:58] Step :  950000, Time :      0.950 [ns], TE :   -2998.5823 [kcal/mol], T :   298.3641 [K], V :    122147.54 [AA^3]
[05:57:30] Checkpointing: Step 959298. . .done
[06:12:31] Checkpointing: Step 998993. . .done
[06:12:54] Step: 1000000
[06:12:54] Checkpointing: Step 1000000. . .done
[06:12:54] GUI Server closing
[06:12:54] GUI Server exiting
[06:12:54] Step : 1000000, Time :      1.000 [ns], TE :   -2980.8505 [kcal/mol], T :   306.1109 [K], V :    119543.92 [AA^3]
[06:12:54] Timing: wall: 21646.54463[s] real, 21440.27258[s] user, 178.61984[s] sys, run: 21538.26888[s], integration: 21462.77848[s], forces: 21066.73325[s].
[06:12:54] Saving result file checkpt
[06:12:54] Saving result file checkpt.crc
[06:12:54] Saving result file par_all27_prot_lipid.inp
[06:12:54] Saving result file protomol.conf
[06:12:54] Saving result file scpismQuartic.inp
[06:12:54] Saving result file ww.dcd
[06:12:58] Saving result file ww_exteq_nowater1.43.pos
[06:12:58] Saving result file ww_exteq_nowater1.43.vel
[06:12:58] Saving result file ww_exteq_nowater1.pdb
[06:12:58] Saving result file ww_exteq_nowater1.psf
[06:12:58] Saving result file ../logfile_06.txt
[06:12:58] CoreStatus = 64 (100)
[06:12:58] Unit 6 finished with 98 percent of time to deadline remaining.
[06:12:58] Updated performance fraction: 0.978554
[06:12:58] Sending work to server
[06:12:58] - Read packet limit of 540015616... Set to 524286976.
[06:12:58] + Attempting to send results
[06:12:58] - Reading file work/wuresults_06.dat from core
[06:12:58]   (Read 12168550 bytes from disk)
[06:12:58] Connecting to http://129.74.85.48:8080/
[07:13:31] - Couldn't send HTTP request to server
[07:13:31] + Could not connect to Work Server (results)
[07:13:31]     (129.74.85.48:8080)
[07:13:31] - Error: Could not transmit unit 06 (completed October 13) to work server.
[07:13:31] - 1 failed uploads of this unit.
[07:13:31]   Keeping unit 06 in queue.
[07:13:31] Trying to send all finished work units
[07:13:31] - Read packet limit of 540015616... Set to 524286976.
[07:13:31] + Attempting to send results
[07:13:31] - Reading file work/wuresults_06.dat from core
[07:13:31]   (Read 12168550 bytes from disk)
[07:13:31] Connecting to http://129.74.85.48:8080/
[08:14:04] - Couldn't send HTTP request to server
[08:14:04] + Could not connect to Work Server (results)
[08:14:04]     (129.74.85.48:8080)
[08:14:04] - Error: Could not transmit unit 06 (completed October 13) to work server.
[08:14:04] - 2 failed uploads of this unit.
[08:14:04] - Read packet limit of 540015616... Set to 524286976.
[08:14:04] + Attempting to send results
[08:14:04] - Reading file work/wuresults_06.dat from core
[08:14:04]   (Read 12168550 bytes from disk)
[08:14:04] Connecting to http://129.74.155.246:8080/
[08:45:32] - Autosending finished units...
[08:45:32] Trying to send all finished work units
[08:45:32] - Already sending work
[08:45:32] + Sent 0 of 1 completed units to the server
[08:45:32] - Autosend completed
[09:14:39] - Couldn't send HTTP request to server
[09:14:39] + Could not connect to Work Server (results)
[09:14:39]     (129.74.155.246:8080)
[09:14:39]   Could not transmit unit 06 to Collection server; keeping in queue.
[09:14:39] + Sent 0 of 1 completed units to the server
[11:29:35] Trying to send all finished work units
[11:29:35] - Read packet limit of 540015616... Set to 524286976.
[11:29:35] + Attempting to send results
[11:29:35] - Reading file work/wuresults_06.dat from core
[11:29:35]   (Read 12168550 bytes from disk)
[11:29:35] Connecting to http://129.74.85.48:8080/
[12:30:14] - Couldn't send HTTP request to server
[12:30:14] + Could not connect to Work Server (results)
[12:30:14]     (129.74.85.48:8080)
[12:30:14] - Error: Could not transmit unit 06 (completed October 13) to work server.
[12:30:14] - 3 failed uploads of this unit.
[12:30:14] - Read packet limit of 540015616... Set to 524286976.
[12:30:14] + Attempting to send results
[12:30:14] - Reading file work/wuresults_06.dat from core
[12:30:14]   (Read 12168550 bytes from disk)
[12:30:14] Connecting to http://129.74.155.246:8080/
[13:56:00] - Couldn't send HTTP request to server
[13:56:00] + Could not connect to Work Server (results)
[13:56:00]     (129.74.85.48:8080)
[13:56:00] - Error: Could not transmit unit 06 (completed October 13) to work server.
[13:56:00] - 3 failed uploads of this unit.
[13:56:00] - Read packet limit of 540015616... Set to 524286976.
[13:56:00] + Attempting to send results
[13:56:00] - Reading file work/wuresults_06.dat from core
[13:56:00]   (Read 12168550 bytes from disk)
[13:56:00] Connecting to http://129.74.155.246:8080/
[14:56:24] - Couldn't send HTTP request to server
[14:56:24] + Could not connect to Work Server (results)
[14:56:24]     (129.74.155.246:8080)
[14:56:24]   Could not transmit unit 06 to Collection server; keeping in queue.
[14:56:24] + Sent 0 of 1 completed units to the server
[14:56:24] - Autosend completed
[20:56:24] - Autosending finished units...
[20:56:24] Trying to send all finished work units
[20:56:24] - Read packet limit of 540015616... Set to 524286976.
[20:56:24] + Attempting to send results
[20:56:24] - Reading file work/wuresults_06.dat from core
[20:56:24]   (Read 12168550 bytes from disk)
[20:56:24] Connecting to http://129.74.85.48:8080/
[21:06:10] Writing local files
[21:06:10] Completed 155000 out of 500000 steps  (31%)
[21:13:44] - Couldn't send HTTP request to server
[21:13:44] + Could not connect to Work Server (results)
[21:13:44]     (129.74.85.48:8080)
[21:13:44] - Error: Could not transmit unit 06 (completed October 13) to work server.
[21:13:44] - 4 failed uploads of this unit.
[21:13:44] - Read packet limit of 540015616... Set to 524286976.
[21:13:44] + Attempting to send results
[21:13:44] - Reading file work/wuresults_06.dat from core
[21:13:44]   (Read 12168550 bytes from disk)
[21:13:44] Connecting to http://129.74.155.246:8080/
[21:21:58] Writing local files
[21:21:58] Completed 160000 out of 500000 steps  (32%)
[21:37:45] Writing local files
[21:37:45] Completed 165000 out of 500000 steps  (33%)
[21:53:35] Writing local files
[21:53:35] Completed 170000 out of 500000 steps  (34%)
[22:09:22] Writing local files
[22:09:23] Completed 175000 out of 500000 steps  (35%)
[22:14:22] - Couldn't send HTTP request to server
[22:14:22] + Could not connect to Work Server (results)
[22:14:22]     (129.74.155.246:8080)
[22:14:22]   Could not transmit unit 06 to Collection server; keeping in queue.
[22:14:22] + Sent 0 of 1 completed units to the server
[22:14:22] - Autosend completed
[22:25:12] Writing local files
[22:25:12] Completed 180000 out of 500000 steps  (36%)
[22:41:01] Writing local files
[22:41:01] Completed 185000 out of 500000 steps  (37%)
[22:56:49] Writing local files
[22:56:49] Completed 190000 out of 500000 steps  (38%)
[23:12:40] Writing local files
[23:12:40] Completed 195000 out of 500000 steps  (39%)
[04:14:22] - Autosending finished units...
[04:14:22] Trying to send all finished work units
[04:14:22] - Read packet limit of 540015616... Set to 524286976.
[04:14:22] + Attempting to send results
[04:14:22] - Reading file work/wuresults_06.dat from core
[04:14:22]   (Read 12168550 bytes from disk)
[04:14:22] Connecting to http://129.74.85.48:8080/
[04:28:49] Writing local files
[04:28:49] Completed 295000 out of 500000 steps  (59%)
[04:44:39] Writing local files
[04:44:39] Completed 300000 out of 500000 steps  (60%)
[05:00:26] Writing local files
[05:00:26] Completed 305000 out of 500000 steps  (61%)
[05:15:38] - Couldn't send HTTP request to server
[05:15:38] + Could not connect to Work Server (results)
[05:15:38]     (129.74.85.48:8080)
[05:15:38] - Error: Could not transmit unit 06 (completed October 13) to work server.
[05:15:38] - 5 failed uploads of this unit.
[05:15:38] - Read packet limit of 540015616... Set to 524286976.
[05:15:38] + Attempting to send results
[05:15:38] - Reading file work/wuresults_06.dat from core
[05:15:38]   (Read 12168550 bytes from disk)
[05:15:38] Connecting to http://129.74.155.246:8080/
[05:16:19] Writing local files
[05:16:19] Completed 310000 out of 500000 steps  (62%)
[05:32:12] Writing local files
[05:32:12] Completed 315000 out of 500000 steps  (63%)
[05:48:00] Writing local files
[05:48:00] Completed 320000 out of 500000 steps  (64%)
[06:03:49] Writing local files
[06:03:49] Completed 325000 out of 500000 steps  (65%)
[06:15:52] - Couldn't send HTTP request to server
[06:15:52] + Could not connect to Work Server (results)
[06:15:52]     (129.74.155.246:8080)
[06:15:52]   Could not transmit unit 06 to Collection server; keeping in queue.
[06:15:52] + Sent 0 of 1 completed units to the server
[06:15:52] - Autosend completed
[06:19:39] Writing local files
[06:19:39] Completed 330000 out of 500000 steps  (66%)
[06:35:29] Writing local files
[06:35:29] Completed 335000 out of 500000 steps  (67%)
[06:51:29] Timered checkpoint triggered.
[06:53:26] Writing local files
[06:53:26] Completed 340000 out of 500000 steps  (68%)
[12:15:52] - Autosending finished units...
[12:15:52] Trying to send all finished work units
[12:15:52] - Read packet limit of 540015616... Set to 524286976.
[12:15:52] + Attempting to send results
[12:15:52] - Reading file work/wuresults_06.dat from core
[12:15:52]   (Read 12168550 bytes from disk)
[12:15:52] Connecting to http://129.74.85.48:8080/
[12:27:07] Writing local files
[12:27:07] Completed 445000 out of 500000 steps  (89%)
[12:42:55] Writing local files
[12:42:55] Completed 450000 out of 500000 steps  (90%)
[12:58:45] Writing local files
[12:58:45] Completed 455000 out of 500000 steps  (91%)
[13:14:33] Writing local files
[13:14:33] Completed 460000 out of 500000 steps  (92%)
[13:16:02] - Couldn't send HTTP request to server
[13:16:02] + Could not connect to Work Server (results)
[13:16:02]     (129.74.85.48:8080)
[13:16:02] - Error: Could not transmit unit 06 (completed October 13) to work server.
[13:16:02] - 6 failed uploads of this unit.
[13:16:02] - Read packet limit of 540015616... Set to 524286976.
[13:16:02] + Attempting to send results
[13:16:02] - Reading file work/wuresults_06.dat from core
[13:16:02]   (Read 12168550 bytes from disk)
[13:16:02] Connecting to http://129.74.155.246:8080/
[13:30:23] Writing local files
[13:30:23] Completed 465000 out of 500000 steps  (93%)
[13:46:12] Writing local files
[13:46:12] Completed 470000 out of 500000 steps  (94%)
[14:01:59] Writing local files
[14:01:59] Completed 475000 out of 500000 steps  (95%)
[14:16:38] - Couldn't send HTTP request to server
[14:16:38] + Could not connect to Work Server (results)
[14:16:38]     (129.74.155.246:8080)
[14:16:38]   Could not transmit unit 06 to Collection server; keeping in queue.
[14:16:38] + Sent 0 of 1 completed units to the server
[14:16:38] - Autosend completed
[14:17:51] Writing local files
[14:17:51] Completed 480000 out of 500000 steps  (96%)
[14:33:40] Writing local files
[14:33:40] Completed 485000 out of 500000 steps  (97%)
[14:49:30] Writing local files
[14:49:30] Completed 490000 out of 500000 steps  (98%)
[15:05:18] Writing local files
[15:05:18] Completed 495000 out of 500000 steps  (99%)
[15:21:07] Writing local files
[15:21:07] Completed 500000 out of 500000 steps  (100%)
[15:21:07] Writing final coordinates.
[15:21:07] Past main M.D. loop
[15:22:07]
[15:22:07] Finished Work Unit:
[15:22:07] - Reading up to 362544 from "work/wudata_07.arc": Read 362544
[15:22:07] - Reading up to 3530920 from "work/wudata_07.xtc": Read 3530920
[15:22:07] goefile size: 0
[15:22:07] logfile size: 894259
[15:22:07] Leaving Run
[15:22:11] - Writing 6552015 bytes of core data to disk...
[15:22:14] Done: 6551503 -> 4756310 (compressed to 72.5 percent)
[15:22:14]   ... Done.
[15:22:14] - Shutting down core
[15:22:14]
[15:22:14] Folding@home Core Shutdown: FINISHED_UNIT
[15:22:15] CoreStatus = 64 (100)
[15:22:15] Unit 7 finished with 98 percent of time to deadline remaining.
[15:22:15] Updated performance fraction: 0.978376
[15:22:15] Sending work to server
[15:22:15] - Read packet limit of 540015616... Set to 524286976.
[15:22:15] + Attempting to send results
[15:22:15] - Reading file work/wuresults_07.dat from core
[15:22:15]   (Read 4756822 bytes from disk)
[15:22:15] Connecting to http://171.64.65.111:8080/
[15:23:45] Posted data.
[15:23:45] Initial: 0000; - Uploaded at ~50 kB/s
[15:23:47] - Averaged speed for that direction ~44 kB/s
[15:23:47] + Results successfully sent
[15:23:47] Thank you for your contribution to Folding@Home.
[15:23:47] + Number of Units Completed: 620
[15:23:47] Trying to send all finished work units
[15:23:47] - Read packet limit of 540015616... Set to 524286976.
[15:23:47] + Attempting to send results
[15:23:47] - Reading file work/wuresults_06.dat from core
[15:23:47]   (Read 12168550 bytes from disk)
[15:23:47] Connecting to http://129.74.85.48:8080/
[16:24:26] - Couldn't send HTTP request to server
[16:24:26] + Could not connect to Work Server (results)
[16:24:26]     (129.74.85.48:8080)
[16:24:26] - Error: Could not transmit unit 06 (completed October 13) to work server.
[16:24:26] - 7 failed uploads of this unit.
[16:24:26] - Read packet limit of 540015616... Set to 524286976.
[16:24:26] + Attempting to send results
[16:24:26] - Reading file work/wuresults_06.dat from core
[16:24:26]   (Read 12168550 bytes from disk)
[16:24:26] Connecting to http://129.74.155.246:8080/
[17:24:54] - Couldn't send HTTP request to server
[17:24:54] + Could not connect to Work Server (results)
[17:24:54]     (129.74.155.246:8080)
[17:24:54]   Could not transmit unit 06 to Collection server; keeping in queue.
[17:24:54] + Sent 0 of 1 completed units to the server
[17:24:54] - Preparing to get new work unit...
[17:24:54] + Attempting to get work packet
[17:24:54] - Detect CPU. Vendor: AuthenticAMD, Family: 15, Model: 11, Stepping: 2
[17:24:54] - Connecting to assignment server
[17:24:54] Connecting to http://assign.stanford.edu:8080/
[17:24:55] Posted data.
[17:24:55] Initial: 40AB; - Successful: assigned to (171.64.65.111).
[17:24:55] + News From Folding@Home: Welcome to Folding@Home
[17:24:55] Loaded queue successfully.
[17:24:55] Connecting to http://171.64.65.111:8080/
[17:24:56] Posted data.
[17:24:56] Initial: 0000; - Receiving payload (expected size: 457934)
[17:24:58] - Downloaded at ~223 kB/s
[17:24:58] - Averaged speed for that direction ~193 kB/s
[17:24:58] + Received work.
[17:24:58] Trying to send all finished work units
[17:24:58] - Read packet limit of 540015616... Set to 524286976.
[17:24:58] + Attempting to send results
[17:24:58] - Reading file work/wuresults_06.dat from core
[17:24:58]   (Read 12168550 bytes from disk)
[17:24:58] Connecting to http://129.74.85.48:8080/
[18:25:54] - Couldn't send HTTP request to server
[18:25:54] + Could not connect to Work Server (results)
[18:25:54]     (129.74.85.48:8080)
[18:25:54] - Error: Could not transmit unit 06 (completed October 13) to work server.
[18:25:54] - 8 failed uploads of this unit.
[18:25:54] - Read packet limit of 540015616... Set to 524286976.
[18:25:54] + Attempting to send results
[18:25:54] - Reading file work/wuresults_06.dat from core
[18:25:54]   (Read 12168550 bytes from disk)
[18:25:54] Connecting to http://129.74.155.246:8080/
[19:26:23] - Couldn't send HTTP request to server
[19:26:23] + Could not connect to Work Server (results)
[19:26:23]     (129.74.155.246:8080)
[19:26:23]   Could not transmit unit 06 to Collection server; keeping in queue.
[19:26:23] + Sent 0 of 1 completed units to the server
[19:26:23] + Closed connections
Re: 129.74.85.48 - unable to send results
Your client is very old ... an upgrade wouldn't hurt.
goodyca
Post by goodyca »
If I am reading the download page correctly, the latest 32-bit build for Linux is version 6.02. This is the version I am running on the subject x86-32 Linux client. The 6.24 beta version is a 64-bit build.
If I have missed a later version for a 32 bit Linux system, let me know where to find it.
protozoa
Post by protozoa »
I have the same problem and have calculated 4 units and many failed uploads for 2 days
--- Opening Log file [October 18 07:35:02 UTC]
Launch directory: C:\F@h\to_send\core1
Executable: C:\F@h\to_send\core1\Folding@home-Win32-x86.exe
Arguments: -send all
[07:35:02] - Ask before connecting: No
[07:35:02] - User name: Protozoa (Team 153624)
[07:35:02] - User ID: 57B96F8241C0E5DA
[07:35:02] - Machine ID: 3
[07:35:02]
[07:35:02] Loaded queue successfully.
[07:35:02] Attempting to return result(s) to server...
[07:35:02] Project: 1031 (Run 200, Clone 0, Gen 0)
[07:35:02] + Attempting to send results [October 18 07:35:02 UTC]
[08:26:51] - Couldn't send HTTP request to server
[08:26:51] + Could not connect to Work Server (results)
[08:26:51]     (129.74.85.48:8080)
[08:26:51] + Retrying using alternative port
[08:26:53] - Couldn't send HTTP request to server
[08:26:53] + Could not connect to Work Server (results)
[08:26:53]     (129.74.85.48:80)
[08:26:53] - Error: Could not transmit unit 09 (completed October 17) to work server.
[08:26:53] + Attempting to send results [October 18 08:26:53 UTC]
[09:07:20] - Couldn't send HTTP request to server
[09:07:20] + Could not connect to Work Server (results)
[09:07:20]     (129.74.155.246:8080)
[09:07:20] + Retrying using alternative port
[09:07:41] - Couldn't send HTTP request to server
[09:07:41] + Could not connect to Work Server (results)
[09:07:41]     (129.74.155.246:80)
[09:07:41]   Could not transmit unit 09 to Collection server; keeping in queue.
[09:07:41] - Failed to send all units to server
Folding@Home Client Shutdown.
these servers are not in server status list and also there is no info about these Project in Currently Running Beta Projects list.
What do you recommend?
P.S. wiil try tomorrow to send unit from another machine
jcoffland
Post by jcoffland »
goodyca:
Server log says "Request from ###.###.###.### cancelled due to connection error". I blocked out your IP address.
Is there anything special about your network? Are you using a proxy? Is it a slow connection?
Protozoa:
The reason your WU is not being accepted is because it has already been accepted once.
Cauldron Development LLC
http://cauldrondevelopment.com/
protozoa
Post by protozoa »
ok, I will delete core, work folders and queue.dat and continue folding.
goodyca
Post by goodyca »
jcoffland wrote:goodyca:
I use a Linksys router to network 4 machines using NAT. No special set up in the router. I don't use a proxy, and I am connecting with a 3 mbps DSL connection. I don't normally have problems with other WU's on this or any of the other machines.
goodyca
Post by goodyca »
After 23 failed upload attempts, the subject WU was successfully uploaded at 14:09 UTC today.
I didn't change anything on this end. Apparently, something may have changed at the server end.
goodyca wrote:After 23 failed upload attempts, the subject WU was successfully uploaded at 14:09 UTC today.
. . . perhaps, or perhaps that bad ethernet cable just happened to produce no errors during the time the WU was uploading. (I'm only half joking. We've had reports much like yours which were eventually traced down to a bad ethernet cable.)
goodyca
Post by goodyca »
Anything is possible. However, a bad Ethernet cable is not a likely explanation unless the bad cable is on the server. The subject machine is a dual core running 2 clients. The two clients have downloaded and uploaded the results for 11 WU's since not being able to upload the subject WU.
Why is the subject server not listed on the server status page?
goodyca wrote:Why is the subject server not listed on the server status page?
I'm not sure.
I do notice that http://129.74.85.48:8080/ works but http://129.74.85.48/ does not, but that may or may not be related.
VijayPande
Pande Group Member
Post by VijayPande »
This server just has been added to serverstat.
Prof. Vijay Pande, PhD
Chair, Biophysics
Stanford University
