Project: 5767 (Run 10, Clone 13, Gen 1242)
ei57
Post by ei57 »
When I mouse over the tray icon, the following appears:
GPU - F@H: Working(xxxx/24090)
The usual reading is (xxxx/15000). The time to complete 1% is also higher, about 54 seconds compared to 34 seconds on a GTX 260 currently at 680/1559/1250. Got two Gigabyte boards today and trying to determine a stable OC. Nice boards running @70C with fans @50 and 60%, default shader @1500 MHz.
Re: Project: 5767 (Run 10, Clone 13, Gen 1242)
Log file please ?
ei57
Post by ei57 »
Nothing special there, but here is the current log:
[15:28:05] Folding@Home GPU Core - Beta
[15:28:05] Version 1.19 (Mon Nov 3 09:34:13 PST 2008)
[15:28:05]
[15:28:05] Compiler  : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 14.00.50727.762 for 80x86
[15:28:05] Build host: amoeba
[15:28:05] Board Type: Nvidia
[15:28:05] Core      :
[15:28:05] Preparing to commence simulation
[15:28:05] - Looking at optimizations...
[15:28:05] - Created dyn
[15:28:05] - Files status OK
[15:28:05] - Expanded 46608 -> 252912 (decompressed 542.6 percent)
[15:28:05] Called DecompressByteArray: compressed_data_size=46608 data_size=252912, decompressed_data_size=252912 diff=0
[15:28:05] - Digital signature verified
[15:28:05]
[15:28:05] Project: 5767 (Run 10, Clone 13, Gen 1242)
[15:28:05]
[15:28:05] Assembly optimizations on if available.
[15:28:05] Entering M.D.
[15:28:11] Working on Protein
[15:28:12] Client config found, loading data.
[15:28:12] Starting GUI Server
[15:29:03] + Paused
[15:29:14] + Working ...
[15:29:14] Suspending work thread...
[15:29:14] Resuming work thread...
[15:29:19] Completed 1%
[15:30:12] Completed 2%
[15:31:06] Completed 3%
[15:32:00] Completed 4%
[15:32:54] Completed 5%
[15:33:48] Completed 6%
[15:34:41] Completed 7%
[15:35:35] Completed 8%
[15:36:29] Completed 9%
[15:37:22] Completed 10%
[15:38:16] Completed 11%
[15:39:10] Completed 12%
[15:40:04] Completed 13%
[15:40:57] Completed 14%
[15:41:51] Completed 15%
[15:42:44] Completed 16%
[15:43:38] Completed 17%
[15:44:14] Timer requesting checkpoint
[15:44:31] Completed 18%
[15:45:25] Completed 19%
[15:46:18] Completed 20%
[15:47:12] Completed 21%
[15:48:05] Completed 22%
[15:48:59] Completed 23%
[15:49:52] Completed 24%
[15:50:46] Completed 25%
[15:51:39] Completed 26%
[15:52:33] Completed 27%
[15:53:27] Completed 28%
[15:54:20] Completed 29%
[15:55:14] Completed 30%
[15:56:08] Completed 31%
[15:57:02] Completed 32%
[15:57:57] Completed 33%
[15:58:52] Completed 34%
[15:59:14] Timer requesting checkpoint
[15:59:46] Completed 35%
[16:00:39] Completed 36%
[16:01:33] Completed 37%
[16:02:26] Completed 38%
[16:03:19] Completed 39%
[16:04:13] Completed 40%
[16:05:06] Completed 41%
[16:06:00] Completed 42%
[16:06:53] Completed 43%
[16:07:47] Completed 44%
[16:08:40] Completed 45%
[16:09:34] Completed 46%
[16:10:27] Completed 47%
[16:11:21] Completed 48%
[16:12:14] Completed 49%
[16:13:08] Completed 50%
[16:14:02] Completed 51%
[16:14:14] Timer requesting checkpoint
[16:14:56] Completed 52%
[16:15:50] Completed 53%
[16:16:44] Completed 54%
[16:17:38] Completed 55%
[16:18:32] Completed 56%
[16:19:26] Completed 57%
[16:20:20] Completed 58%
[16:21:14] Completed 59%
[16:22:08] Completed 60%
[16:23:03] Completed 61%
[16:23:56] Completed 62%
[16:24:50] Completed 63%
[16:25:44] Completed 64%
[16:26:38] Completed 65%
[16:27:31] Completed 66%
[16:28:25] Completed 67%
[16:29:14] Timer requesting checkpoint
[16:29:19] Completed 68%
[16:30:13] Completed 69%
[16:31:06] Completed 70%
[16:32:00] Completed 71%
[16:32:54] Completed 72%
[16:33:47] Completed 73%
[16:34:41] Completed 74%
[16:35:35] Completed 75%
[16:36:28] Completed 76%
[16:37:22] Completed 77%
[16:38:17] Completed 78%
[16:39:10] Completed 79%
[16:40:04] Completed 80%
[16:40:58] Completed 81%
[16:41:52] Completed 82%
[16:42:46] Completed 83%
[16:43:40] Completed 84%
[16:44:14] Timer requesting checkpoint
[16:44:34] Completed 85%
[16:45:27] Completed 86%
