Project: 2677 (Run 13, Clone 3, Gen 41)
pwnchu
Post by pwnchu »
Tag: P2677R13C3G41
Download time: August 31 09:34:59
Due time: September 3 09:34:59
Progress: 1723161577%
[09:36:32] Project: 2677 (Run 13, Clone 3, Gen 41)
[09:36:32]
[09:36:32] Assembly optimizations on if available.
[09:36:32] Entering M.D.
[09:36:39]  on if available.
[09:36:39] Entering M.D.
[09:36:45] Multi-core optimizations on
[09:37:33] Completed 0 out of 249999 steps  (0%)
I think it is folding on two cores (It's a VM and appears to be using both). What should I do?
Re: Project: 2677 (Run 13, Clone 3, Gen 41)
The weird value in unitinfo file is cosmetic issue, no need to worry about.
It should fold at a normal speed ...
pwnchu
Post by pwnchu »
Thanks! I will assume the 249999 steps part is ok.
Yes there's sometimes some weird number like 249999 or 250001 ... but it's not a bug :mrgreen:
pwnchu
Post by pwnchu »
Bah, it hung at 2%. VMware was giving me some weird displays so I will try to fix it.
