A possible Virus associated from Folding [False positive]
We have had a moderator on our folding team have a virus detected in a his folding work folder. Evga folding forum is where the discussion can be viewed. Thanks, Mvgratz team 111065
Re: A possible Virus associated from Folding.
http://www.evga.com/forums/tm.asp?m=100 ... #100837910 This is a link to the discussion. The first post has a link to the specific virus and file it was found in. Thanks
v00d00
- 16GB DDR3,
- Zotac GTX 1050Ti @ Stock.
- Gigabyte GTX 970 @ Stock
Debian 9.
Most likely a false positive.
The files generated by FAH while working most likely were arranged in a way that set off the heuristics algorithm causing it to flag the file(s).
Ive run FAH for 5 years and we see an odd false positive once every so often.
Re: A possible Virus associated from Folding [False positive]
He's using avast. Search this forum for "avast false" and see how many hits you get.
