On XBOX 360?
impossiblerubix
On XBOX 360?
Anyone here think that Folding@Home will every be on the XBOX 360? It could run off of the 360's GPU. It has a pretty powerful GPU.
DanGe
- Hardware configuration: 2018 Mac Mini / MacOS Catalina
3.2 GHz 6-Core Intel Core i7 - Location: California, United States
Re: On XBOX 360?
Unfortunately, there are no plans for it.
viewtopic.php?f=3&t=8342
shatteredsilicon
- Hardware configuration: 1x Q6600 @ 3.2GHz, 4GB DDR3-1333
1x Phenom X4 9950 @ 2.6GHz, 4GB DDR2-1066
3x GeForce 9800GX2
1x GeForce 8800GT
CentOS 5 x86-64, WINE 1.x with CUDA wrappers
Re: On XBOX 360?
It wouldn't be worthwhile. PowerPC performance is appalling, and there are no compilers available that can vectorize code on VMX128 (Xenon FPU is a bit different to the standard PPC970 - Xenon is missing about 20 Altivec instructions, but has additional 128 registers).
MtM
Re: On XBOX 360?
xbox360 is not worth the effort, there is a better link then the one posted about one of the previous xbox360 thread's, namely one which explains why 'device x' will not get a client in any case and that no matter the amount of threads on it that would not change
It was a response on the amount of threads about this, so sometimes using search does help to answer some questions.
