Is there any way to remove / merge members of a team?
What I have done is before I knew about the machine id settings. I had created a few names for each of my computers that I have running FAH so it is, Daniel, Daniel 2 ECT.
Is there any way to remove these or merge the WU and Score to one name?
Thanks.
Remove or merge members of a team.
- Hardware configuration: =========RIG ONE=========
Processor: Intel(R) Core(TM)i5 CPU M 520 @ 2.40GHz
Memory: 6 GB
Operating System: Kubuntu 10.04
Kernel: 2.6.32-24-generic
To be continued... - Location: Alexandroupolis, Greece
Re: Remove or merge members of a team.
NIce question! If I can add a bit more, would it be possible in the future to change your username?
It is not possible to merge scores once they have been added to the stats system (imagine if a big user with several million points decided to change teams and take their points with them... could make a big difference in the rankings). As a result, it is possible to change your username but units already completed and returned cannot be moved to a new username/team.
Folding whatever I'm sent since March 2006 Beta testing since October 2006. www.FAH-Addict.net Administrator since August 2009.
Ok so if you cant take the points with you. Can you have a username removed for a team? and keep the points. I just want to get rid of a few copies of my account.John Naylor wrote:It is not possible to merge scores once they have been added to the stats system (imagine if a big user with several million points decided to change teams and take their points with them... could make a big difference in the rankings). As a result, it is possible to change your username but units already completed and returned cannot be moved to a new username/team.
Sadly not. Once scores are in the system, they are there permanently, as is the username they were assigned to.
And also team number.John Naylor wrote:Sadly not. Once scores are in the system, they are there permanently, as is the username they were assigned to.
If someone contributes to your team and you don't want them on your team, their name and their points stay. The policy is: No adjustments will be made.
