GPU WUs giving base points?
Doctrinaire
Hardware configuration: Windows 10 x64-bit
F@H client: V7.5.1
Intel i5-7600k
AMD MSI RX 480 Gaming X 8gb
Re: GPU WUs giving base points?
Post by Doctrinaire »
Update:
The "refresh" in the log viewer seems to have reloaded my configuration when new WUs start. So far my last 3 WUs over the past couple days have been giving my full "estimated points" upon completion. Not entirely sure if the refresh it what fixed it, or if it just sorted itself out on its own. At any rate, I am not seeing any WUs give only base points.
So to anyone reading this forum post, if you are having issues with WUs not giving full credit, give your F@H client a "refresh" in the log tab of the application. Its worth a try. As well as not letting any WUs sit paused, your points will decrease until the assignment is completed and submitted. Also, i've been setting my GPU to "finish" and not pausing it while it works. Perhaps that is also helping my points/WU.
Post by Neil-B »
Not pausing WUs whether CPU of GPU will mean they get returned quicker which is better for the science and increases the points (if within Timeout) … The QRB "clock" does not stop ticking when a machine is paused or switched off … It is calculated from when the WS sends it out to when the WS gets it back - you can look up any WU in you log at https://apps.foldingathome.org/wu and compare the "Days" to the Project Summary which details Timeout and Expiry Deadlines https://apps.foldingathome.org/psummary
FAH will show signs of instability log before artifacts are visible on the screen. FAH doesn't use the video generation components. Reducing the power to that part of the chip just leave more watts/heat that can go to the shaders, encouraging them to be unstable.
Officialy, FAH does not support overclocking. Sure, "everybody" does it and experienced overclockers will generally offer an opinion, but you're strictly on your own as far as offical "support" is concerned -- but you already knew that.
ChalkyMeteor
Post by ChalkyMeteor »
I am getting the same behaviour described by Doctrinaire - I'm concerned this might have a discouraging effect for some users.
This is my most recent fold - Estimated 70139, received 9,405
https://apps.foldingathome.org/wu?p=145 ... 856&gen=72
03:54:36:WU01:FS01:Downloading 4.51MiB
03:54:42:WU01:FS01:Download 31.85%
03:54:48:WU01:FS01:Download 67.85%
03:54:53:WU01:FS01:Download complete
03:54:53:WU01:FS01:Received Unit: id:01 state:DOWNLOAD error:NO_ERROR project:11743 run:0 clone:7220 gen:72 core:0x22 unit:0x000000688ca304f15e6bc492c88f5426
03:54:53:WU01:FS01:Starting
03:54:53:WU01:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\ChalkyMeteor\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/Core_22.fah/FahCore_22.exe -dir 01 -suffix 01 -version 706 -lifeline 24116 -checkpoint 15 -gpu-vendor amd -opencl-platform 0 -opencl-device 0 -gpu 0
03:54:53:WU01:FS01:Started FahCore on PID 23852
03:54:53:WU01:FS01:Core PID:17428
03:54:53:WU01:FS01:FahCore 0x22 started
03:54:54:WU01:FS01:0x22:*********************** Log Started 2020-04-25T03:54:54Z ***********************
03:54:54:WU01:FS01:0x22:*************************** Core22 Folding@home Core ***************************
03:54:54:WU01:FS01:0x22:       Type: 0x22
03:54:54:WU01:FS01:0x22:       Core: Core22
03:54:54:WU01:FS01:0x22:    Website: https://foldingathome.org/
03:54:54:WU01:FS01:0x22:  Copyright: (c) 2009-2018 foldingathome.org
03:54:54:WU01:FS01:0x22:     Author: John Chodera <john.chodera@choderalab.org> and Rafal Wiewiora
03:54:54:WU01:FS01:0x22:             <rafal.wiewiora@choderalab.org>
03:54:54:WU01:FS01:0x22:       Args: -dir 01 -suffix 01 -version 706 -lifeline 23852 -checkpoint 15
03:54:54:WU01:FS01:0x22:             -gpu-vendor amd -opencl-platform 0 -opencl-device 0 -gpu 0
03:54:54:WU01:FS01:0x22:     Config: <none>
03:54:54:WU01:FS01:0x22:************************************ Build *************************************
03:54:54:WU01:FS01:0x22:    Version: 0.0.2
03:54:54:WU01:FS01:0x22:       Date: Dec 6 2019
03:54:54:WU01:FS01:0x22:       Time: 21:30:31
03:54:54:WU01:FS01:0x22: Repository: Git
03:54:54:WU01:FS01:0x22:   Revision: abeb39247cc72df5af0f63723edafadb23d5dfbe
03:54:54:WU01:FS01:0x22:     Branch: HEAD
03:54:54:WU01:FS01:0x22:   Compiler: Visual C++ 2008
03:54:54:WU01:FS01:0x22:    Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
03:54:54:WU01:FS01:0x22:   Platform: win32 10
03:54:54:WU01:FS01:0x22:       Bits: 64
03:54:54:WU01:FS01:0x22:       Mode: Release
03:54:54:WU01:FS01:0x22:************************************ System ************************************
03:54:54:WU01:FS01:0x22:        CPU: Intel(R) Core(TM) i7-6770HQ CPU @ 2.60GHz
03:54:54:WU01:FS01:0x22:     CPU ID: GenuineIntel Family 6 Model 94 Stepping 3
03:54:54:WU01:FS01:0x22:       CPUs: 8
03:54:54:WU01:FS01:0x22:     Memory: 31.89GiB
03:54:54:WU01:FS01:0x22:Free Memory: 23.83GiB
03:54:54:WU01:FS01:0x22:    Threads: WINDOWS_THREADS
03:54:54:WU01:FS01:0x22: OS Version: 6.2
03:54:54:WU01:FS01:0x22:Has Battery: false
03:54:54:WU01:FS01:0x22: On Battery: false
03:54:54:WU01:FS01:0x22: UTC Offset: 10
03:54:54:WU01:FS01:0x22:        PID: 17428
03:54:54:WU01:FS01:0x22:        CWD: C:\Users\ChalkyMeteor\AppData\Roaming\FAHClient\work
03:54:54:WU01:FS01:0x22:         OS: Windows 10 Pro
03:54:54:WU01:FS01:0x22:    OS Arch: AMD64
03:54:54:WU01:FS01:0x22:********************************************************************************
03:54:54:WU01:FS01:0x22:Project: 11743 (Run 0, Clone 7220, Gen 72)
03:54:54:WU01:FS01:0x22:Unit: 0x000000688ca304f15e6bc492c88f5426
03:54:54:WU01:FS01:0x22:Reading tar file core.xml
03:54:54:WU01:FS01:0x22:Reading tar file integrator.xml
03:54:54:WU01:FS01:0x22:Reading tar file state.xml
03:54:54:WU01:FS01:0x22:Reading tar file system.xml
03:54:55:WU01:FS01:0x22:Digital signatures verified
03:54:55:WU01:FS01:0x22:Folding@home GPU Core22 Folding@home Core
03:54:55:WU01:FS01:0x22:Version 0.0.2
03:55:06:WU01:FS01:0x22:Completed 0 out of 2000000 steps (0%)
03:55:06:WU01:FS01:0x22:Temperature control disabled. Requirements: single Nvidia GPU, tmax must be < 110 and twait >= 900
03:56:36:WU01:FS01:0x22:Completed 20000 out of 2000000 steps (1%)
03:58:04:WU01:FS01:0x22:Completed 40000 out of 2000000 steps (2%)
03:59:35:WU01:FS01:0x22:Completed 60000 out of 2000000 steps (3%)
04:01:04:WU01:FS01:0x22:Completed 80000 out of 2000000 steps (4%)
04:02:33:WU01:FS01:0x22:Completed 100000 out of 2000000 steps (5%)
04:04:04:WU01:FS01:0x22:Completed 120000 out of 2000000 steps (6%)
04:05:33:WU01:FS01:0x22:Completed 140000 out of 2000000 steps (7%)
04:07:05:WU01:FS01:0x22:Completed 160000 out of 2000000 steps (8%)
04:08:35:WU01:FS01:0x22:Completed 180000 out of 2000000 steps (9%)
04:10:06:WU01:FS01:0x22:Completed 200000 out of 2000000 steps (10%)
04:11:42:WU01:FS01:0x22:Completed 220000 out of 2000000 steps (11%)
04:13:11:WU01:FS01:0x22:Completed 240000 out of 2000000 steps (12%)
04:14:43:WU01:FS01:0x22:Completed 260000 out of 2000000 steps (13%)
04:16:13:WU01:FS01:0x22:Completed 280000 out of 2000000 steps (14%)
04:17:46:WU01:FS01:0x22:Completed 300000 out of 2000000 steps (15%)
04:19:21:WU01:FS01:0x22:Completed 320000 out of 2000000 steps (16%)
04:20:54:WU01:FS01:0x22:Completed 340000 out of 2000000 steps (17%)
04:22:30:WU01:FS01:0x22:Completed 360000 out of 2000000 steps (18%)
04:24:03:WU01:FS01:0x22:Completed 380000 out of 2000000 steps (19%)
04:25:35:WU01:FS01:0x22:Completed 400000 out of 2000000 steps (20%)
04:27:08:WU01:FS01:0x22:Completed 420000 out of 2000000 steps (21%)
04:28:39:WU01:FS01:0x22:Completed 440000 out of 2000000 steps (22%)
04:30:12:WU01:FS01:0x22:Completed 460000 out of 2000000 steps (23%)
04:31:42:WU01:FS01:0x22:Completed 480000 out of 2000000 steps (24%)
04:33:12:WU01:FS01:0x22:Completed 500000 out of 2000000 steps (25%)
04:34:44:WU01:FS01:0x22:Completed 520000 out of 2000000 steps (26%)
04:36:15:WU01:FS01:0x22:Completed 540000 out of 2000000 steps (27%)
04:37:48:WU01:FS01:0x22:Completed 560000 out of 2000000 steps (28%)
04:39:19:WU01:FS01:0x22:Completed 580000 out of 2000000 steps (29%)
04:40:49:WU01:FS01:0x22:Completed 600000 out of 2000000 steps (30%)
04:42:22:WU01:FS01:0x22:Completed 620000 out of 2000000 steps (31%)
04:43:53:WU01:FS01:0x22:Completed 640000 out of 2000000 steps (32%)
04:45:26:WU01:FS01:0x22:Completed 660000 out of 2000000 steps (33%)
04:46:57:WU01:FS01:0x22:Completed 680000 out of 2000000 steps (34%)
04:48:28:WU01:FS01:0x22:Completed 700000 out of 2000000 steps (35%)
04:50:01:WU01:FS01:0x22:Completed 720000 out of 2000000 steps (36%)
04:51:31:WU01:FS01:0x22:Completed 740000 out of 2000000 steps (37%)
04:53:04:WU01:FS01:0x22:Completed 760000 out of 2000000 steps (38%)
04:54:35:WU01:FS01:0x22:Completed 780000 out of 2000000 steps (39%)
******************************* Date: 2020-04-25 *******************************
04:56:06:WU01:FS01:0x22:Completed 800000 out of 2000000 steps (40%)
04:57:39:WU01:FS01:0x22:Completed 820000 out of 2000000 steps (41%)
04:59:10:WU01:FS01:0x22:Completed 840000 out of 2000000 steps (42%)
05:00:43:WU01:FS01:0x22:Completed 860000 out of 2000000 steps (43%)
05:02:13:WU01:FS01:0x22:Completed 880000 out of 2000000 steps (44%)
05:03:43:WU01:FS01:0x22:Completed 900000 out of 2000000 steps (45%)
05:05:16:WU01:FS01:0x22:Completed 920000 out of 2000000 steps (46%)
05:06:47:WU01:FS01:0x22:Completed 940000 out of 2000000 steps (47%)
05:08:20:WU01:FS01:0x22:Completed 960000 out of 2000000 steps (48%)
05:09:50:WU01:FS01:0x22:Completed 980000 out of 2000000 steps (49%)
05:11:19:WU01:FS01:0x22:Completed 1000000 out of 2000000 steps (50%)
05:12:51:WU01:FS01:0x22:Completed 1020000 out of 2000000 steps (51%)
05:14:22:WU01:FS01:0x22:Completed 1040000 out of 2000000 steps (52%)
05:15:55:WU01:FS01:0x22:Completed 1060000 out of 2000000 steps (53%)
05:17:25:WU01:FS01:0x22:Completed 1080000 out of 2000000 steps (54%)
05:18:54:WU01:FS01:0x22:Completed 1100000 out of 2000000 steps (55%)
05:20:26:WU01:FS01:0x22:Completed 1120000 out of 2000000 steps (56%)
05:21:57:WU01:FS01:0x22:Completed 1140000 out of 2000000 steps (57%)
05:23:29:WU01:FS01:0x22:Completed 1160000 out of 2000000 steps (58%)
05:24:58:WU01:FS01:0x22:Completed 1180000 out of 2000000 steps (59%)
05:26:29:WU01:FS01:0x22:Completed 1200000 out of 2000000 steps (60%)
05:28:02:WU01:FS01:0x22:Completed 1220000 out of 2000000 steps (61%)
05:28:40:84:127.0.0.1:New Web session
05:28:49:85:127.0.0.1:New Web session
05:29:32:WU01:FS01:0x22:Completed 1240000 out of 2000000 steps (62%)
05:31:05:WU01:FS01:0x22:Completed 1260000 out of 2000000 steps (63%)
05:32:35:WU01:FS01:0x22:Completed 1280000 out of 2000000 steps (64%)
05:34:05:WU01:FS01:0x22:Completed 1300000 out of 2000000 steps (65%)
05:35:38:WU01:FS01:0x22:Completed 1320000 out of 2000000 steps (66%)
05:37:08:WU01:FS01:0x22:Completed 1340000 out of 2000000 steps (67%)
05:38:40:WU01:FS01:0x22:Completed 1360000 out of 2000000 steps (68%)
05:40:09:WU01:FS01:0x22:Completed 1380000 out of 2000000 steps (69%)
05:41:39:WU01:FS01:0x22:Completed 1400000 out of 2000000 steps (70%)
05:43:10:WU01:FS01:0x22:Completed 1420000 out of 2000000 steps (71%)
05:44:41:WU01:FS01:0x22:Completed 1440000 out of 2000000 steps (72%)
05:46:14:WU01:FS01:0x22:Completed 1460000 out of 2000000 steps (73%)
05:47:46:WU01:FS01:0x22:Completed 1480000 out of 2000000 steps (74%)
05:49:17:WU01:FS01:0x22:Completed 1500000 out of 2000000 steps (75%)
05:50:50:WU01:FS01:0x22:Completed 1520000 out of 2000000 steps (76%)
05:52:20:WU01:FS01:0x22:Completed 1540000 out of 2000000 steps (77%)
05:53:53:WU01:FS01:0x22:Completed 1560000 out of 2000000 steps (78%)
05:55:24:WU01:FS01:0x22:Completed 1580000 out of 2000000 steps (79%)
05:56:55:WU01:FS01:0x22:Completed 1600000 out of 2000000 steps (80%)
05:58:27:WU01:FS01:0x22:Completed 1620000 out of 2000000 steps (81%)
05:59:59:WU01:FS01:0x22:Completed 1640000 out of 2000000 steps (82%)
06:01:33:WU01:FS01:0x22:Completed 1660000 out of 2000000 steps (83%)
06:03:04:WU01:FS01:0x22:Completed 1680000 out of 2000000 steps (84%)
06:04:33:WU01:FS01:0x22:Completed 1700000 out of 2000000 steps (85%)
06:06:06:WU01:FS01:0x22:Completed 1720000 out of 2000000 steps (86%)
06:07:37:WU01:FS01:0x22:Completed 1740000 out of 2000000 steps (87%)
06:09:09:WU01:FS01:0x22:Completed 1760000 out of 2000000 steps (88%)
06:10:39:WU01:FS01:0x22:Completed 1780000 out of 2000000 steps (89%)
06:12:10:WU01:FS01:0x22:Completed 1800000 out of 2000000 steps (90%)
06:13:43:WU01:FS01:0x22:Completed 1820000 out of 2000000 steps (91%)
06:15:13:WU01:FS01:0x22:Completed 1840000 out of 2000000 steps (92%)
06:16:46:WU01:FS01:0x22:Completed 1860000 out of 2000000 steps (93%)
06:18:17:WU01:FS01:0x22:Completed 1880000 out of 2000000 steps (94%)
06:19:47:WU01:FS01:0x22:Completed 1900000 out of 2000000 steps (95%)
06:21:21:WU01:FS01:0x22:Completed 1920000 out of 2000000 steps (96%)
06:22:51:WU01:FS01:0x22:Completed 1940000 out of 2000000 steps (97%)
06:24:22:WU01:FS01:0x22:Completed 1960000 out of 2000000 steps (98%)
06:25:51:WU01:FS01:0x22:Completed 1980000 out of 2000000 steps (99%)
06:25:51:WU00:FS01:Connecting to 65.254.110.245:80
06:25:52:WARNING:WU00:FS01:Failed to get assignment from '65.254.110.245:80': No WUs available for this configuration
06:25:52:WU00:FS01:Connecting to 18.218.241.186:80
06:25:53:WARNING:WU00:FS01:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
06:25:53:WU00:FS01:Connecting to 65.254.110.245:80
06:25:53:WARNING:WU00:FS01:Failed to get assignment from '65.254.110.245:80': No WUs available for this configuration
06:25:53:WU00:FS01:Connecting to 18.218.241.186:80
06:25:54:WARNING:WU00:FS01:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
06:25:54:ERROR:WU00:FS01:Exception: Could not get an assignment
06:25:54:WU00:FS01:Connecting to 65.254.110.245:80
06:25:55:WARNING:WU00:FS01:Failed to get assignment from '65.254.110.245:80': No WUs available for this configuration
06:25:55:WU00:FS01:Connecting to 18.218.241.186:80
06:25:56:WARNING:WU00:FS01:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
06:25:56:WU00:FS01:Connecting to 65.254.110.245:80
06:25:57:WARNING:WU00:FS01:Failed to get assignment from '65.254.110.245:80': No WUs available for this configuration
06:25:57:WU00:FS01:Connecting to 18.218.241.186:80
06:25:57:WARNING:WU00:FS01:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
06:25:57:ERROR:WU00:FS01:Exception: Could not get an assignment
06:26:54:WU00:FS01:Connecting to 65.254.110.245:80
06:26:55:WARNING:WU00:FS01:Failed to get assignment from '65.254.110.245:80': No WUs available for this configuration
06:26:55:WU00:FS01:Connecting to 18.218.241.186:80
06:26:56:WARNING:WU00:FS01:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
06:26:56:WU00:FS01:Connecting to 65.254.110.245:80
06:26:57:WARNING:WU00:FS01:Failed to get assignment from '65.254.110.245:80': No WUs available for this configuration
06:26:57:WU00:FS01:Connecting to 18.218.241.186:80
06:26:57:WARNING:WU00:FS01:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
06:26:57:ERROR:WU00:FS01:Exception: Could not get an assignment
06:27:23:WU01:FS01:0x22:Completed 2000000 out of 2000000 steps (100%)
06:27:25:WU01:FS01:0x22:Saving result file ..\logfile_01.txt
06:27:25:WU01:FS01:0x22:Saving result file checkpointState.xml
06:27:27:WU01:FS01:0x22:Saving result file checkpt.crc
06:27:27:WU01:FS01:0x22:Saving result file positions.xtc
06:27:29:WU01:FS01:0x22:Saving result file science.log
06:27:29:WU01:FS01:0x22:Folding@home Core Shutdown: FINISHED_UNIT
06:27:29:WU01:FS01:FahCore returned: FINISHED_UNIT (100 = 0x64)
06:27:29:WU01:FS01:Sending unit results: id:01 state:SEND error:NO_ERROR project:11743 run:0 clone:7220 gen:72 core:0x22 unit:0x000000688ca304f15e6bc492c88f5426
06:27:29:WU01:FS01:Uploading 12.56MiB to 140.163.4.241
06:27:29:WU01:FS01:Connecting to 140.163.4.241:8080
06:28:32:WU00:FS01:Connecting to 65.254.110.245:80
06:28:32:WARNING:WU00:FS01:Failed to get assignment from '65.254.110.245:80': No WUs available for this configuration
06:28:32:WU00:FS01:Connecting to 18.218.241.186:80
06:28:33:WU00:FS01:Assigned to work server 13.82.98.119
06:28:33:WU00:FS01:Requesting new work unit for slot 01: READY gpu:0:Vega 10 XL/XT [Radeon RX Vega 56/64] from 13.82.98.119
06:28:33:WU00:FS01:Connecting to 13.82.98.119:8080
06:28:50:WU01:FS01:Upload 1.49%
06:28:54:WARNING:WU00:FS01:WorkServer connection failed on port 8080 trying 80
06:28:54:WU00:FS01:Connecting to 13.82.98.119:80
06:28:56:WU01:FS01:Upload 12.44%
06:29:02:WU01:FS01:Upload 24.38%
06:29:09:WU01:FS01:Upload 37.32%
06:29:15:WU01:FS01:Upload 49.76%
06:29:15:ERROR:WU00:FS01:Exception: Failed to connect to 13.82.98.119:80: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
06:29:21:WU01:FS01:Upload 58.71%
06:29:27:WU01:FS01:Upload 71.15%
06:29:33:WU01:FS01:Upload 83.59%
06:29:39:WU01:FS01:Upload 96.03%
06:29:44:WU01:FS01:Upload complete
06:29:45:WU01:FS01:Server responded WORK_ACK (400)
06:29:45:WU01:FS01:Final credit estimate, 70139.00 points
06:29:45:WU01:FS01:Cleaning up
Same with my fold before that - Estimated 40601, received 5,692
https://apps.foldingathome.org/wu?p=145 ... 856&gen=71
01:23:26:WU00:FS01:Requesting new work unit for slot 01: RUNNING gpu:0:Vega 10 XL/XT [Radeon RX Vega 56/64] from 13.82.98.119
01:23:26:WU00:FS01:Connecting to 13.82.98.119:8080
01:23:56:WU00:FS01:Downloading 13.26MiB
01:24:02:WU00:FS01:Download 11.78%
01:24:08:WU00:FS01:Download 24.98%
01:24:14:WU00:FS01:Download 38.18%
01:24:20:WU00:FS01:Download 50.91%
01:24:26:WU00:FS01:Download 64.11%
01:24:32:WU00:FS01:Download 77.30%
01:24:38:WU00:FS01:Download 90.03%
01:24:42:WU00:FS01:Download complete
01:24:42:WU00:FS01:Received Unit: id:00 state:DOWNLOAD error:NO_ERROR project:14538 run:0 clone:1856 gen:71 core:0x22 unit:0x000000600d5262775e7b9cda3af1206d
01:24:47:WU01:FS01:0x22:Completed 2000000 out of 2000000 steps (100%)
01:24:49:WU01:FS01:0x22:Saving result file ..\logfile_01.txt
01:24:49:WU01:FS01:0x22:Saving result file checkpointState.xml
01:24:51:WU01:FS01:0x22:Saving result file checkpt.crc
01:24:51:WU01:FS01:0x22:Saving result file positions.xtc
01:24:53:WU01:FS01:0x22:Saving result file science.log
01:24:53:WU01:FS01:0x22:Folding@home Core Shutdown: FINISHED_UNIT
01:24:53:WU01:FS01:FahCore returned: FINISHED_UNIT (100 = 0x64)
01:24:53:WU01:FS01:Sending unit results: id:01 state:SEND error:NO_ERROR project:11749 run:0 clone:4795 gen:13 core:0x22 unit:0x000000188ca304e75e6a80171f9d540a
01:24:53:WU01:FS01:Uploading 12.57MiB to 140.163.4.231
01:24:53:WU01:FS01:Connecting to 140.163.4.231:8080
01:24:53:WU00:FS01:Starting
01:24:53:WU00:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\ChalkyMeteor\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/Core_22.fah/FahCore_22.exe -dir 00 -suffix 01 -version 706 -lifeline 24116 -checkpoint 15 -gpu-vendor amd -opencl-platform 0 -opencl-device 0 -gpu 0
01:24:56:WU00:FS01:Started FahCore on PID 10680
01:24:56:WU00:FS01:Core PID:148
01:24:56:WU00:FS01:FahCore 0x22 started
01:24:57:WU00:FS01:0x22:*********************** Log Started 2020-04-25T01:24:57Z ***********************
01:24:57:WU00:FS01:0x22:*************************** Core22 Folding@home Core ***************************
01:24:57:WU00:FS01:0x22:       Type: 0x22
01:24:57:WU00:FS01:0x22:       Core: Core22
01:24:57:WU00:FS01:0x22:    Website: https://foldingathome.org/
01:24:57:WU00:FS01:0x22:  Copyright: (c) 2009-2018 foldingathome.org
01:24:57:WU00:FS01:0x22:     Author: John Chodera <john.chodera@choderalab.org> and Rafal Wiewiora
01:24:57:WU00:FS01:0x22:             <rafal.wiewiora@choderalab.org>
01:24:57:WU00:FS01:0x22:       Args: -dir 00 -suffix 01 -version 706 -lifeline 10680 -checkpoint 15
01:24:57:WU00:FS01:0x22:             -gpu-vendor amd -opencl-platform 0 -opencl-device 0 -gpu 0
01:24:57:WU00:FS01:0x22:     Config: <none>
01:24:57:WU00:FS01:0x22:************************************ Build *************************************
01:24:57:WU00:FS01:0x22:    Version: 0.0.2
01:24:57:WU00:FS01:0x22:       Date: Dec 6 2019
01:24:57:WU00:FS01:0x22:       Time: 21:30:31
01:24:57:WU00:FS01:0x22: Repository: Git
01:24:57:WU00:FS01:0x22:   Revision: abeb39247cc72df5af0f63723edafadb23d5dfbe
01:24:57:WU00:FS01:0x22:     Branch: HEAD
01:24:57:WU00:FS01:0x22:   Compiler: Visual C++ 2008
01:24:57:WU00:FS01:0x22:    Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
01:24:57:WU00:FS01:0x22:   Platform: win32 10
01:24:57:WU00:FS01:0x22:       Bits: 64
01:24:57:WU00:FS01:0x22:       Mode: Release
01:24:57:WU00:FS01:0x22:************************************ System ************************************
01:24:57:WU00:FS01:0x22:        CPU: Intel(R) Core(TM) i7-6770HQ CPU @ 2.60GHz
01:24:57:WU00:FS01:0x22:     CPU ID: GenuineIntel Family 6 Model 94 Stepping 3
01:24:57:WU00:FS01:0x22:       CPUs: 8
01:24:57:WU00:FS01:0x22:     Memory: 31.89GiB
01:24:57:WU00:FS01:0x22:Free Memory: 23.62GiB
01:24:57:WU00:FS01:0x22:    Threads: WINDOWS_THREADS
01:24:57:WU00:FS01:0x22: OS Version: 6.2
01:24:57:WU00:FS01:0x22:Has Battery: false
01:24:57:WU00:FS01:0x22: On Battery: false
01:24:57:WU00:FS01:0x22: UTC Offset: 10
01:24:57:WU00:FS01:0x22:        PID: 148
01:24:57:WU00:FS01:0x22:        CWD: C:\Users\ChalkyMeteor\AppData\Roaming\FAHClient\work
01:24:57:WU00:FS01:0x22:         OS: Windows 10 Pro
01:24:57:WU00:FS01:0x22:    OS Arch: AMD64
01:24:57:WU00:FS01:0x22:********************************************************************************
01:24:57:WU00:FS01:0x22:Project: 14538 (Run 0, Clone 1856, Gen 71)
01:24:57:WU00:FS01:0x22:Unit: 0x000000600d5262775e7b9cda3af1206d
01:24:57:WU00:FS01:0x22:Reading tar file core.xml
01:24:57:WU00:FS01:0x22:Reading tar file integrator.xml
01:24:57:WU00:FS01:0x22:Reading tar file state.xml
01:24:57:WU00:FS01:0x22:Reading tar file system.xml
01:24:57:WU00:FS01:0x22:Digital signatures verified
01:24:57:WU00:FS01:0x22:Folding@home GPU Core22 Folding@home Core
01:24:57:WU00:FS01:0x22:Version 0.0.2
01:25:05:WU00:FS01:0x22:Completed 0 out of 4000000 steps (0%)
01:25:05:WU00:FS01:0x22:Temperature control disabled. Requirements: single Nvidia GPU, tmax must be < 110 and twait >= 900
01:26:27:WU01:FS01:Upload 1.49%
01:26:30:WU00:FS01:0x22:Completed 40000 out of 4000000 steps (1%)
01:26:33:WU01:FS01:Upload 12.93%
01:26:39:WU01:FS01:Upload 25.37%
01:26:45:WU01:FS01:Upload 38.30%
01:26:51:WU01:FS01:Upload 50.74%
01:26:57:WU01:FS01:Upload 62.67%
01:27:03:WU01:FS01:Upload 75.61%
01:27:09:WU01:FS01:Upload 83.56%
01:27:15:WU01:FS01:Upload 95.50%
01:27:20:WU01:FS01:Upload complete
01:27:20:WU01:FS01:Server responded WORK_ACK (400)
01:27:20:WU01:FS01:Final credit estimate, 71780.00 points
01:27:20:WU01:FS01:Cleaning up
01:27:37:41:127.0.0.1:New Web session
01:27:57:WU00:FS01:0x22:Completed 80000 out of 4000000 steps (2%)
01:29:21:WU00:FS01:0x22:Completed 120000 out of 4000000 steps (3%)
01:30:46:WU00:FS01:0x22:Completed 160000 out of 4000000 steps (4%)
01:32:12:WU00:FS01:0x22:Completed 200000 out of 4000000 steps (5%)
01:33:39:WU00:FS01:0x22:Completed 240000 out of 4000000 steps (6%)
01:35:04:WU00:FS01:0x22:Completed 280000 out of 4000000 steps (7%)
01:36:31:WU00:FS01:0x22:Completed 320000 out of 4000000 steps (8%)
01:37:55:WU00:FS01:0x22:Completed 360000 out of 4000000 steps (9%)
01:39:19:WU00:FS01:0x22:Completed 400000 out of 4000000 steps (10%)
01:40:47:WU00:FS01:0x22:Completed 440000 out of 4000000 steps (11%)
01:42:15:WU00:FS01:0x22:Completed 480000 out of 4000000 steps (12%)
01:43:42:WU00:FS01:0x22:Completed 520000 out of 4000000 steps (13%)
01:45:09:WU00:FS01:0x22:Completed 560000 out of 4000000 steps (14%)
01:46:33:WU00:FS01:0x22:Completed 600000 out of 4000000 steps (15%)
01:48:01:WU00:FS01:0x22:Completed 640000 out of 4000000 steps (16%)
01:49:26:WU00:FS01:0x22:Completed 680000 out of 4000000 steps (17%)
01:50:53:WU00:FS01:0x22:Completed 720000 out of 4000000 steps (18%)
01:52:21:WU00:FS01:0x22:Completed 760000 out of 4000000 steps (19%)
01:53:47:WU00:FS01:0x22:Completed 800000 out of 4000000 steps (20%)
01:55:12:WU00:FS01:0x22:Completed 840000 out of 4000000 steps (21%)
01:56:39:WU00:FS01:0x22:Completed 880000 out of 4000000 steps (22%)
01:58:07:WU00:FS01:0x22:Completed 920000 out of 4000000 steps (23%)
01:59:33:WU00:FS01:0x22:Completed 960000 out of 4000000 steps (24%)
02:00:58:WU00:FS01:0x22:Completed 1000000 out of 4000000 steps (25%)
02:02:25:WU00:FS01:0x22:Completed 1040000 out of 4000000 steps (26%)
02:03:16:WU00:FS01:0x22:Bad State detected... attempting to resume from last good checkpoint. Is your system overclocked?
02:03:16:WU00:FS01:0x22:Following exception occured: Particle coordinate is nan
02:04:20:WU00:FS01:0x22:Completed 1080000 out of 4000000 steps (27%)
02:05:48:WU00:FS01:0x22:Completed 1120000 out of 4000000 steps (28%)
02:07:16:WU00:FS01:0x22:Completed 1160000 out of 4000000 steps (29%)
02:08:41:WU00:FS01:0x22:Completed 1200000 out of 4000000 steps (30%)
02:10:09:WU00:FS01:0x22:Completed 1240000 out of 4000000 steps (31%)
02:11:37:WU00:FS01:0x22:Completed 1280000 out of 4000000 steps (32%)
02:13:04:WU00:FS01:0x22:Completed 1320000 out of 4000000 steps (33%)
02:14:31:WU00:FS01:0x22:Completed 1360000 out of 4000000 steps (34%)
02:15:58:WU00:FS01:0x22:Completed 1400000 out of 4000000 steps (35%)
02:17:28:WU00:FS01:0x22:Completed 1440000 out of 4000000 steps (36%)
02:18:54:WU00:FS01:0x22:Completed 1480000 out of 4000000 steps (37%)
02:20:20:WU00:FS01:0x22:Completed 1520000 out of 4000000 steps (38%)
02:21:48:WU00:FS01:0x22:Completed 1560000 out of 4000000 steps (39%)
02:23:13:WU00:FS01:0x22:Completed 1600000 out of 4000000 steps (40%)
02:24:38:WU00:FS01:0x22:Completed 1640000 out of 4000000 steps (41%)
02:26:03:WU00:FS01:0x22:Completed 1680000 out of 4000000 steps (42%)
02:27:29:WU00:FS01:0x22:Completed 1720000 out of 4000000 steps (43%)
02:28:57:WU00:FS01:0x22:Completed 1760000 out of 4000000 steps (44%)
02:30:22:WU00:FS01:0x22:Completed 1800000 out of 4000000 steps (45%)
02:31:47:WU00:FS01:0x22:Completed 1840000 out of 4000000 steps (46%)
02:33:12:WU00:FS01:0x22:Completed 1880000 out of 4000000 steps (47%)
02:34:36:WU00:FS01:0x22:Completed 1920000 out of 4000000 steps (48%)
02:36:05:WU00:FS01:0x22:Completed 1960000 out of 4000000 steps (49%)
02:37:30:WU00:FS01:0x22:Completed 2000000 out of 4000000 steps (50%)
02:38:57:WU00:FS01:0x22:Completed 2040000 out of 4000000 steps (51%)
02:40:25:WU00:FS01:0x22:Completed 2080000 out of 4000000 steps (52%)
02:41:51:WU00:FS01:0x22:Completed 2120000 out of 4000000 steps (53%)
02:43:18:WU00:FS01:0x22:Completed 2160000 out of 4000000 steps (54%)
02:44:43:WU00:FS01:0x22:Completed 2200000 out of 4000000 steps (55%)
02:46:10:WU00:FS01:0x22:Completed 2240000 out of 4000000 steps (56%)
02:47:36:WU00:FS01:0x22:Completed 2280000 out of 4000000 steps (57%)
02:49:02:WU00:FS01:0x22:Completed 2320000 out of 4000000 steps (58%)
02:50:28:WU00:FS01:0x22:Completed 2360000 out of 4000000 steps (59%)
02:51:53:WU00:FS01:0x22:Completed 2400000 out of 4000000 steps (60%)
02:53:19:WU00:FS01:0x22:Completed 2440000 out of 4000000 steps (61%)
02:54:47:WU00:FS01:0x22:Completed 2480000 out of 4000000 steps (62%)
02:56:14:WU00:FS01:0x22:Completed 2520000 out of 4000000 steps (63%)
02:57:41:WU00:FS01:0x22:Completed 2560000 out of 4000000 steps (64%)
02:59:06:WU00:FS01:0x22:Completed 2600000 out of 4000000 steps (65%)
03:00:33:WU00:FS01:0x22:Completed 2640000 out of 4000000 steps (66%)
03:01:58:WU00:FS01:0x22:Completed 2680000 out of 4000000 steps (67%)
03:03:25:WU00:FS01:0x22:Completed 2720000 out of 4000000 steps (68%)
03:04:50:WU00:FS01:0x22:Completed 2760000 out of 4000000 steps (69%)
03:06:17:WU00:FS01:0x22:Completed 2800000 out of 4000000 steps (70%)
03:07:41:WU00:FS01:0x22:Completed 2840000 out of 4000000 steps (71%)
03:09:10:WU00:FS01:0x22:Completed 2880000 out of 4000000 steps (72%)
03:10:36:WU00:FS01:0x22:Completed 2920000 out of 4000000 steps (73%)
03:12:03:WU00:FS01:0x22:Completed 2960000 out of 4000000 steps (74%)
03:13:28:WU00:FS01:0x22:Completed 3000000 out of 4000000 steps (75%)
03:14:55:WU00:FS01:0x22:Completed 3040000 out of 4000000 steps (76%)
03:16:24:WU00:FS01:0x22:Completed 3080000 out of 4000000 steps (77%)
03:17:49:WU00:FS01:0x22:Completed 3120000 out of 4000000 steps (78%)
03:19:17:WU00:FS01:0x22:Completed 3160000 out of 4000000 steps (79%)
03:20:44:WU00:FS01:0x22:Completed 3200000 out of 4000000 steps (80%)
03:22:14:WU00:FS01:0x22:Completed 3240000 out of 4000000 steps (81%)
03:23:43:WU00:FS01:0x22:Completed 3280000 out of 4000000 steps (82%)
03:25:12:WU00:FS01:0x22:Completed 3320000 out of 4000000 steps (83%)
03:26:42:WU00:FS01:0x22:Completed 3360000 out of 4000000 steps (84%)
03:28:08:WU00:FS01:0x22:Completed 3400000 out of 4000000 steps (85%)
03:29:36:WU00:FS01:0x22:Completed 3440000 out of 4000000 steps (86%)
03:31:03:WU00:FS01:0x22:Completed 3480000 out of 4000000 steps (87%)
03:32:31:WU00:FS01:0x22:Completed 3520000 out of 4000000 steps (88%)
03:34:01:WU00:FS01:0x22:Completed 3560000 out of 4000000 steps (89%)
03:35:28:WU00:FS01:0x22:Completed 3600000 out of 4000000 steps (90%)
03:36:55:WU00:FS01:0x22:Completed 3640000 out of 4000000 steps (91%)
03:38:24:WU00:FS01:0x22:Completed 3680000 out of 4000000 steps (92%)
03:39:52:WU00:FS01:0x22:Completed 3720000 out of 4000000 steps (93%)
03:41:21:WU00:FS01:0x22:Completed 3760000 out of 4000000 steps (94%)
03:42:48:WU00:FS01:0x22:Completed 3800000 out of 4000000 steps (95%)
03:44:17:WU00:FS01:0x22:Completed 3840000 out of 4000000 steps (96%)
03:45:46:WU00:FS01:0x22:Completed 3880000 out of 4000000 steps (97%)
03:47:14:WU00:FS01:0x22:Completed 3920000 out of 4000000 steps (98%)
03:48:43:WU00:FS01:0x22:Completed 3960000 out of 4000000 steps (99%)
03:48:44:WU01:FS01:Connecting to 65.254.110.245:80
03:48:45:WARNING:WU01:FS01:Failed to get assignment from '65.254.110.245:80': No WUs available for this configuration
03:48:45:WU01:FS01:Connecting to 18.218.241.186:80
03:48:46:WU01:FS01:Assigned to work server 128.252.203.10
03:48:46:WU01:FS01:Requesting new work unit for slot 01: RUNNING gpu:0:Vega 10 XL/XT [Radeon RX Vega 56/64] from 128.252.203.10
03:48:46:WU01:FS01:Connecting to 128.252.203.10:8080
03:49:07:WARNING:WU01:FS01:WorkServer connection failed on port 8080 trying 80
03:49:07:WU01:FS01:Connecting to 128.252.203.10:80
03:49:28:ERROR:WU01:FS01:Exception: Failed to connect to 128.252.203.10:80: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
03:49:28:WU01:FS01:Connecting to 65.254.110.245:80
03:49:29:WARNING:WU01:FS01:Failed to get assignment from '65.254.110.245:80': No WUs available for this configuration
03:49:29:WU01:FS01:Connecting to 18.218.241.186:80
03:49:30:WARNING:WU01:FS01:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
03:49:30:WU01:FS01:Connecting to 65.254.110.245:80
03:49:30:WARNING:WU01:FS01:Failed to get assignment from '65.254.110.245:80': No WUs available for this configuration
03:49:30:WU01:FS01:Connecting to 18.218.241.186:80
03:49:31:WARNING:WU01:FS01:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
03:49:31:ERROR:WU01:FS01:Exception: Could not get an assignment
03:50:11:WU00:FS01:0x22:Completed 4000000 out of 4000000 steps (100%)
03:50:12:WU00:FS01:0x22:Saving result file ..\logfile_01.txt
03:50:12:WU00:FS01:0x22:Saving result file badstate-0.xml
03:50:12:WU00:FS01:0x22:Saving result file checkpointState.xml
03:50:12:WU00:FS01:0x22:Saving result file checkpt.crc
03:50:12:WU00:FS01:0x22:Saving result file positions.xtc
03:50:12:WU00:FS01:0x22:Saving result file science.log
03:50:12:WU00:FS01:0x22:Folding@home Core Shutdown: FINISHED_UNIT
03:50:13:WU00:FS01:FahCore returned: FINISHED_UNIT (100 = 0x64)
03:50:13:WU00:FS01:Sending unit results: id:00 state:SEND error:NO_ERROR project:14538 run:0 clone:1856 gen:71 core:0x22 unit:0x000000600d5262775e7b9cda3af1206d
03:50:13:WU00:FS01:Uploading 17.96MiB to 13.82.98.119
03:50:13:WU00:FS01:Connecting to 13.82.98.119:8080
03:50:21:WU00:FS01:Upload 0.70%
03:50:28:WU01:FS01:Connecting to 65.254.110.245:80
03:50:29:WARNING:WU01:FS01:Failed to get assignment from '65.254.110.245:80': No WUs available for this configuration
03:50:29:WU01:FS01:Connecting to 18.218.241.186:80
03:50:29:WARNING:WU01:FS01:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
03:50:29:WU01:FS01:Connecting to 65.254.110.245:80
03:50:30:WU01:FS01:Assigned to work server 140.163.4.241
03:50:30:WU01:FS01:Requesting new work unit for slot 01: READY gpu:0:Vega 10 XL/XT [Radeon RX Vega 56/64] from 140.163.4.241
03:50:30:WU01:FS01:Connecting to 140.163.4.241:8080
03:50:56:WU00:FS01:Upload 1.04%
03:51:02:WU00:FS01:Upload 9.74%
03:51:08:WU00:FS01:Upload 19.14%
03:51:14:WU00:FS01:Upload 28.53%
03:51:20:WU00:FS01:Upload 37.58%
03:51:26:WU00:FS01:Upload 46.97%
03:51:32:WU00:FS01:Upload 56.02%
03:51:38:WU00:FS01:Upload 65.41%
03:51:44:WU00:FS01:Upload 74.80%
03:51:50:WU00:FS01:Upload 84.20%
03:51:56:WU00:FS01:Upload 93.59%
03:52:00:WU00:FS01:Upload complete
03:52:01:WU00:FS01:Server responded WORK_ACK (400)
03:52:01:WU00:FS01:Final credit estimate, 40601.00 points
03:52:01:WU00:FS01:Cleaning up
Current config
15:49:35:Saving configuration to config.xml
15:49:35:<config>
15:49:35:  <!-- Folding Slot Configuration -->
15:49:35:  <cause v='COVID_19'/>
15:49:35:
15:49:35:  <!-- Network -->
15:49:35:  <proxy v=':8080'/>
15:49:35:
15:49:35:  <!-- Slot Control -->
15:49:35:  <power v='full'/>
15:49:35:
15:49:35:  <!-- User Information -->
15:49:35:  <passkey v='*****'/>
15:49:35:  <team v='235955'/>
15:49:35:  <user v='ChalkyMeteor'/>
15:49:35:
15:49:35:  <!-- Folding Slots -->
15:49:35:  <slot id='1' type='GPU'/>
15:49:35:</config>
If you check the FAQ for the Quick Retun Bonus, you'll find that there are three reasons why you don't get a bonus.
1) The first 10 WU that you fold never get a bonus.
2) If you fail to maintain at least an 80% successful completion rate you won't get a bonus.
3) No bonus is awarded if you fail to return the WU by the Timeout.
The FAH log doesn't query this status for items 1 or 2; it assumes you will get one.
ChalkyMeteor
Ah, thanks that makes more sense. Probably worth adding that the estimated amount is the QRB amount, because that wasn't clear in the app/logs.
Is it after 10 *passkey* folds? I'm at 65 total, but only 4 here - https://apps.foldingathome.org/bonus
Welcome to the F@H Forum ChalkyMeteor,
Please note that the 10 WUs should be submitted with the same username+passkey combination. If you initially submitted WUs with just the username and then added the passkey, the initial WUs without the passkey will not count towards it.
Doctrinaire
F@H client: V7.5.1
Intel i5-7600k
Chalkymeteor,
It appears that you are at 6/10 WUs towards your bonus. So on your 5th WU from now, you should start to see that bonus.
If you do not start to see the bonus after that point, then you can try some of the following things that seem to have worked for me.
1) Make sure to "refresh" your log in the Log tab in the F@H advance client. It should re-load your configuration and WU passkey/bonus.
2) Let WUs run until finished and don't pause them. As you pause them, the point value that you'll get decrease.
Returning WUs quicker results, generally, in a higher point amount. The scientists and researchers that need the data that we could need the WUs sent back in a timely manner, so they can continue their work.
